Old 07-03-2012, 10:14 PM   #1
bawag
bawag's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Providing easy to follow photo tutorials for members on how to replace tierod ends on a Cortina.
Default TC Cortina Tie Rod End Replacement Guide
Carried out this job today and thought i would do another write up for those people that are interested.
First i jacked up the car and put it on stands, next thing i did was crack the adjusting nut.
Then cut the cable tie that holds the boot to the tie rod, this enables you to twist the tie rod.
Then undo the top retaining nut. Split the ball joint with the ball joint removal tool
Undo the ball joint off the end of the tie rod,
check the old one against the new one to make sure it has the same thread and length etc.
Install the new part back on the rack end and screw it on as close as possible to where the original one was
tighten the top lock nut and put in the split pin if its not a nylock
Tighten up the larger adjusting nut (22mm) grease the nipple and take the car for a wheel alignment, but i might try this myself on the weekend if the rain ever holds out!
Ben
bawag is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2012, 01:44 PM   #2
oysta
Escort MkII 1977 2.0L
Default Re: TC Cortina Tie Rod End Replacement Guide
Nice writeup and photos Ben.
Looks like a few other rubbers might need replacing soon.
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2012, 03:09 PM   #3
bawag
bawag's Avatar
Yeah soon! at the moment its not a daily driver so theres no rush
Old 10-03-2012, 12:10 AM   #4
TC200six
The link pin bushes are no better than the ones on mine, but mine has more cobwebs underneath too.
TC200six is offline   Reply With Quote Multi-Quote with this Post
