Old 04-12-2011, 12:03 AM   #1
Firebell AU3SR
Firebell AU3SR's Avatar
Default Drivers Door Stuck???
Hi All,
Just arrived home and went to open the drivers door as normal but I got no response from the inside handle (stiff as). Also tried the outside handle via the window- no response!! Got out via passengers side and tried with the key , no response with little turn. If I lock my car with the key pad without leaving a window down, I will not be able to open it again. Any ideas how I can get the door open and what has gone wrong in regards to the lock?? Where is the best place to take the car too??
cheers
Steve
Firebell AU3SR is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2011, 08:17 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Drivers Door Stuck???
My first move would to ring a few panel beaters, explain the problem and ask if they have a fix for it.
Old 06-12-2011, 01:28 AM   #3
Firebell AU3SR
Thanks GasOLane for your reply.
UPDATE:
I finally got the door open by pulling & pulling on the snipper rod and the interior handle at the same time. After removing the door trim etc, I soon discovered that the section of the actuator that controls the rods has seized up.I will be replacing the actuator tomorrow with a new one.
Old 06-12-2011, 08:25 PM   #4
Firebell AU3SR
UPDATE:
New actuator installed and everything is back to normal again.
Old 06-12-2011, 10:49 PM   #5
im bak
Originally Posted by Firebell AU3SR
UPDATE:
May I ask how much a new actuator cost? New or reco? I have a similar issue....but not jamming, using remote will not close or open car, but key will.
im bak is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2011, 01:32 AM   #6
Firebell AU3SR
Cost me $140 all up (Trade via a mate) new from Ford. The BA/BF Actuator is a big improvement over the orignal AU one (more metal parts and a built in guide for the door handle rod). The door now closes much better. When you purchase the actuator you also have to purchase a wire harness adapter (different plugs between models) and a new door handle rod due to the change in angle.
In your case, it sounds like your plastic cog has broken which is a common problem. I replaced my 12 months ago. You can buy them on Ebay or upgrade with a complete new actuator.
Old 08-12-2011, 04:57 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
I've bought two from these guys, cheap fast service (overnight post) 3 years ago and had no problems yet.
http://stores.ebay.com.au/STRUT-ACTU...2&_sc=1&_sop=1
