Old 01-11-2011, 03:42 AM   #1
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Default Wsid 2/11/11
If the weather stays warm i should be out at WSID on Wednesday. Anybody else making plans?
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 10:47 AM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
Default Re: Wsid 2/11/11
Yep be there with Michael...
Daily driver GTE FG..
Old 01-11-2011, 01:11 PM   #3
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Ill be there Saturday if anyone is coming out. Did you pick up the terri pipe?
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 04:12 PM   #4
FPV GTHO
not yet. Gunna go just with the chasers and have some fun, see what difference higher psi makes, see if i can get over the line in 2nd. think i can still go faster given my mph
Old 01-11-2011, 05:37 PM   #5
Falc'man
You dig, we stick!
Falc'man's Avatar
You probably could go over in second.
Would be interesting to see if your times improve by using the upper revs - my best times were when I left it in sports mode. It sounds faster holding the gears to past 6000 but the timeslips never agreed with my ears.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2011, 10:28 PM   #6
FPV GTHO
So far ive done it in sports mode as well, but its on 25psi in the tyres as well. Maybe something in the 30's would get the tyre diameter high enough to keep 2nd over the line. I think its going to hit the limiter though based on how early it gets into 3rd.
Old 02-11-2011, 10:16 AM   #7
Giant
Giant's Avatar
I can get to the line in 2nd but have to change right on the line but I have less power then you and also 1 second slower ET. I have found short changing 2nd at around 5500 can give good results. Have fun!
I pulled my last PB by running 45 psi on the rears which was a mistake but worked out well. I only got 1 good run after that each time i just got tyre smoke.
+1 for sports mode.
Old 02-11-2011, 08:01 PM   #8
FPV GTHO
good night for me so far already. A new pb already 14.515@96.95 although im running with no lh headlight to feed the growler direct air. Combo on that was 35psi and manual shifting at 5500rpm. Been trying =iants idea with the aircon and it seems to be working. Infact that run i forgot to turn it off after staging!
Old 02-11-2011, 09:03 PM   #9
Giant
Giant's Avatar
Good work mate a new PB. Now try screwing the BBM tab screw in as far as it goes with out falling out the otherside. Just need a flat head screwdrive 1 min job. count the threads so you know can set back to normal if u dont like screw towards the unbent side so the short runner butterflys are slightly open at idle.
Old 02-11-2011, 09:05 PM   #10
Giant
Giant's Avatar
Try pumping the fronts up to 55psi. rears 45psi and add a extra 10 litres of fuel should be enff to stop the spin maybe make it 15. Have you removed the Dust / Coil Cover off the rocket cover if not do so it traps heat. Good to replace it for daily driving.
Old 02-11-2011, 09:27 PM   #11
Giant
Giant's Avatar
Are you going to get another run before the 9pm burn out comp?
Old 02-11-2011, 09:32 PM   #12
FPV GTHO
just ran then so dont think so
Old 02-11-2011, 09:34 PM   #13
Giant
Giant's Avatar
If you hanging around goodluck with cracking a 14.4
Old 02-11-2011, 09:36 PM   #14
XRCIST
XRCIST's Avatar
Nice times mate!! I take it your still on the standard tune? What was your 60ft time?
XRCIST is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2011, 02:25 AM   #15
FPV GTHO
Yeah still standard tune. I think i'll be holding off on the tune until im ready to also do cams. That 14.515 was with a 2.178 60ft. My net 2 runs following that were a 14.511 and 14.507 with a 2.204 and 2.188 60ft. Best run of the night came after them with 14.425 and a 2.160 60ft. Ended up doing 9 runs through the night.
Old 03-11-2011, 09:32 AM   #16
Giant
Giant's Avatar
Woooo great work mate smashed the 14.5 barrier. What was the temp last night should be able to go faster next winter.
Looking at your 60ft times you should invest in some better rubber for the rear or look at setup for improved and consistent launching.
Did you try anything else for the later runs?
Old 03-11-2011, 06:53 PM   #17
XRCIST
XRCIST's Avatar
Well done mate, im very impressed!! 98.9mph is absolutely hauling for the mods done. Just goes to show how much better the NA BF motor is than the BA version. The best i got out of my combo NA was 14.28 @ 98mph and that was with 4.10s and a Tune.
Didnt see it in your mod list but get yourself a set of underdrives, mine picked up 2 tenths after fitting them and 1.2mph - 1.5mph IIRC.
Your 60ft of 2.16 was also the exact same as mine before i did gears. For some reason i couldnt get it lower than that. This was on 18s as well. After i did the gears it went 2.100 in the 60 carrying more weight and in warmer conditions.
A tune and 4.10s will really bring your car together and make it one very quick and consistent streeter. Top Effort!!!
Hopefully i can get down to Calder next Saturday for a couple of runs if the weather holds out, you've given me the itch to go down asap lol
Old 04-11-2011, 01:16 AM   #18
Stav
Smile
Stav's Avatar
You are capable of 14.3. To 14.2 with your car. Just get the setup right you will do it
Old 04-11-2011, 10:28 AM   #19
Giant
Giant's Avatar
+1 for the 20% underdrives
Would keep your money in your pocket regarding the 4.1 gears and buy a LSD first.
Get some sticky rear tyres.
Put a switch on your thermo fans so you can turn them off at the lights.
At 98mph Doogster set the record of 13.7 ET with Slicks, skinny front runners and weight reduction. 4.11 gears 3000 Stally and Tune.
Old 04-11-2011, 10:33 AM   #20
Stav
Smile
Stav's Avatar
I'd recommend 3.9 diff ratio personally because the 4:11 s do feel like they slow you down at the end of the track. 3.9 will help you utilize top end power better while giving great increase in acceleration
Old 04-11-2011, 10:50 PM   #21
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
No he didn't...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2011, 11:16 PM   #22
Falc'man
You dig, we stick!
Falc'man's Avatar
Congrats on the PB! They're great times, especially considering the warmer temps. Well done
Stav, the 4sp is very tall, 4.1s are the go.
Old 04-11-2011, 11:17 PM   #23
FreddyDUZ747
FreddyDUZ747's Avatar
Thumbs up Re: Wsid 2/11/11
Excellent result bloke,5 tenths slower than my BA turbo when it was 100% stock.Yours would be way more fun though at that 1/4 mile time/power
What premium fuel are you running,e10 100 from United is the best imo?
Another tip to try,if you have good stick street tires(Neuton nt5000 are good in 18s)avoid the water and just stage the car without a burnout and try the run,you may be suprised.Do you have a lsd,you may bot even need it,pump the wheel that spins less likely up 10psi more
Just trying to get you that every little bit,I recon that air con/thermo fan idea was mine to lol,I now have the switch/s so that no fans are on when leaving the line,not even low speed.PM me if you want the wire colours to tap into and ill draw you a diagram.I miss my old 167rwkw BA Futura MK11 Wagontwas fun,used to bag the left wheel for donkeys years.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2011, 11:20 PM   #24
FreddyDUZ747
Also,go the 2.5" catback!
Just saw the mph also,that aint hanging around at all.
Old 04-11-2011, 11:43 PM   #25
FPV GTHO
Thanks for all the responses guys. If anyones interested ive posted alll the timing margins etc from each run in my build thread in thebseries.com.au section.
Anybody else think a sticky WSID R4R thread would be worth a shot?
Old 05-11-2011, 11:11 AM   #26
Road Games
Road Games's Avatar
Definately ...
Have a read of this too ... ya might have to wait til next winter tho'
http://www.fordforums.com.au/showthread.php?t=11222517
I was very proud to be part of that ^^^ So grab an underdrive mate ...
Old 05-11-2011, 03:05 PM   #27
XRCIST
XRCIST's Avatar
Whats the trick with the aircon? Im curious hehe
The thermo fans kicking in on the start line were responsible for my mediocre times so a switch to turn them off would be helpful. They would activate on the start line and hot air would blow straight on my air filter. To make matters worse, the intercooler pipe goes through the space under the headlight and due to the angle it passes through it blocks nearly all of the incoming air through that spot. Taking out the light would be my best bet for the drags like you did FPVGTHO.
Old 05-11-2011, 04:28 PM   #28
Road Games
Road Games's Avatar
Having the aircon on may drop your rad temp but the Hi-speed fans still heat up the intake manifold , spacers or not!
I disconnect the fans before my burnout.... motor comes up to temp quickly and the run cools the rad down, i re-connect them on the return road...
Old 05-11-2011, 08:13 PM   #29
FPV GTHO
This is coming from Giant, you turn the AC on which will turn on the thermos regardless of engine temp. I think its something mainly for those with the cooler thermos but the standard ECU settings for the fans.
Well this is the second time ive done it, and whilst this time a number of factors led to me dropping my times by another tenth and a half, last time when going back to back weeks it only had a benefit of 0.002!
Daz ive only got one large central fan, you're talking about yours like you're running 2? Maybe another BA/BF difference there?
Old 05-11-2011, 10:01 PM   #30
Road Games
Road Games's Avatar
Ah yes grasshopper... mine has 2 as do all FPV's and all std BA 6's...
