Old 09-10-2011, 06:59 PM   #1
taybelZ
Default what are the essentials you do on your car
So we purchased a second hand 08 Auto zetec with 60,000 on the clock.
Its got full service history, however i have a habit of servicing it myself.
Other then spark plugs, air filter, oil, oil filter and fuel filter.
What other 'essentials' do you replace?
I just like the idea of knowing everything has been changed over to my satisfaction.
taybelZ is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2011, 07:20 PM   #2
Marquis 351
Marquis 351's Avatar
Default Re: what are the essentials you do on your car
Discs, pads and carbon filter. An 08 Ford What??
Marquis 351 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2011, 07:50 PM   #3
marg99
You should also ensure the brake fluid was replaced each 3 years and the radiator coolant every 4 years ( red coloured additive).
While not factory recommended an auto transmission service each 50,000 klm is advised to give you longer transmission life
Old 09-10-2011, 10:32 PM   #4
rand0mn00b
in addition to the above a quick mention for the power steering fluid - reservoir is located under the driver's side front headlight
this is apparently because it is not meant to ever be serviced for the life of the vehicle. well i personally check on it to make sure it's still green and the level hasn't dropped. it will eventually yellow/brown but will do so slowly even though it's never meant to be changed i don't believe that
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
