Old 03-10-2011, 07:56 PM   #1
BHDOGS
Default fairmont irs
OK i have a v8 fairmont series 2 now as i understand fairmonts had the option of having irs fitted but didnt come standard with it so how can i tell if my car has irs or not might be a stupid question but im an eseries guy this is my first au and all the stuff is different now.
Old 03-10-2011, 08:38 PM   #2
T3man
T3man's Avatar
Default Re: fairmont irs
Have a look under the back - does it have a solid beam axle? If so it is the basic Watt's Link set-up. On the other hand if you see two exposed half-shafts going from the diff to the wheel hub carriers then it has IRS.
Old 03-10-2011, 08:39 PM   #3
Jimmyd
Solid non IRS (just like your e-series)
IRS
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2011, 08:40 PM   #4
T3man
T3man's Avatar
Purrfect - good on you Jim.
Old 03-10-2011, 10:14 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Another way to tell is to weigh your wallet - if you have IRS it will be rather light.
Old 03-10-2011, 11:01 PM   #6
BHDOGS
Hahah ive heard this cheers guys ill stick my head under tomorrow and have a looksie
Old 09-10-2011, 09:45 PM   #7
BHDOGS
seems i have a regular diff which im happy about
Old 09-10-2011, 11:23 PM   #8
Mr Hardware
Good to hear mate - expect to have virtually 0 trouble with your falcon's rear end for many hundreds of thousands of kays to come.
Oh except for the odd trailing arm bush, but they're a half hour fix not a 4 hour fix!
Old 10-10-2011, 01:58 AM   #9
BHDOGS
should be able to get a better sway bar fitted to just gota lose this huge towbar on my car i think its the 2600 kilo one becoz its massive
