Old 20-09-2011, 08:48 AM   #1
chazza
chazza's Avatar
Default Surge tank stroker AU
SURGE TANK
Any body have any basic info for fitting and product to an AU V8
1/4 to 1/2 a tank and she runs out of juice ..corners and take offs mainly.
chazza is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 08:40 PM   #2
Pinkbits
Pinkbits's Avatar
Default Re: Surge tank stroker AU
Turn the pick up 180 degrees.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 09:21 PM   #3
chazza
chazza's Avatar
I rekin your on the money. Maybe instead of sharp left fuel vanishes now it'll be to the right. Just want to do it right once.
Old 21-09-2011, 02:25 AM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Sounds like the internal baffle's come adrift. You can access your fuel pump through the boot, run the tank empty and pull it out. There should be a white plastic baffle inside the tank. You can either clip it back on or have something fabricated that'll fit through the hole (about 4inch diameter from memory)
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2011, 05:42 AM   #5
chazza
chazza's Avatar
Do you mean a part of the tank has come apart or fuel pump housing
Old 21-09-2011, 10:01 AM   #6
mongrelEF
Bugger!
mongrelEF's Avatar
It clips onto the bottom of the tank, on the inside. It's like a cup that the fuel pump drops inside. When you accelerate or go round corners, it holds fuel up to the pump.
The fuel pump pick up is located about half an inch off the bottom of the tank and points straight down. If you're getting fuel slosh off a half full tank, a) You're going round corners far too hard ; and b) that would suggest the internal baffling isn't there......
Or the tank could be full of crap and the pump picks it up when you slosh it around.
Old 21-09-2011, 10:40 AM   #7
chazza
chazza's Avatar
Great info thanks
The car has a lot more torque than orig, so wouldn't have been noticable before.
I'll get stuck into it
Old 22-09-2011, 08:14 PM   #8
adumb
FG G6ET
adumb's Avatar
Very helpful! Thank you!
I'm having the same problem...but I only have a standard VCT 6 lol
2009 FG G6E Turbo
adumb is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2011, 09:46 PM   #9
mongrelEF
Bugger!
mongrelEF's Avatar
No problems, happy to help
Old 24-09-2011, 06:27 PM   #10
chazza
chazza's Avatar
Nothin to do so put a new radiator in one car
On a roll so I checked the fuel pump
The pump on the right is a spare. Put that in and made sure fitted in snugly into the tray. (is the tray supposed to be loose) seems dodge
So far going fine
Old 24-09-2011, 11:41 PM   #11
mongrelEF
Bugger!
mongrelEF's Avatar
The tray shouldn't be very loose. Since it just clips onto a plastic lump, it will wiggle a little, but not a lot (technical answer )
Old 24-09-2011, 11:59 PM   #12
chazza
chazza's Avatar
LOL Couple of scotches..Ain't gonna touch that one
Old 25-09-2011, 12:04 AM   #13
mongrelEF
Bugger!
mongrelEF's Avatar
Haha I'm good at thinking. I think a lot. The problem is, most of my thoughts should not be inflicted on the general population
Old 03-10-2011, 10:58 AM   #14
chazza
chazza's Avatar
So far so good.
No loss of fuel with low tank of gas.
Maybe the splash tray had become dislodged.
Made sure it was positioned right into the fuel pump.
There is a lump for the splash tray to fit into tank but dodge as.
Very happy
