Old 28-08-2011, 10:15 PM   #1
Ricknel76
Default speed alert
Hi All,
just wanted to ask how to turn on and set the speed alert on an AU s3.
Also there is a function on the remote key pad that will only unlock the drivers door on the first press and then the second press unlocks the other doors.
I gather that this information is in the owners manual that I dont have.
Rick
Ricknel76 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2011, 11:21 PM   #2
Beer Baron
Default Re: speed alert
Hold the seek button on the steering wheel till it beeps shows up on the LCD display in the cluster. Use the volume controls to adjust the speed i think. Its been a long time since I've used it.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2011, 03:41 PM   #3
KEVSXR8
KEVSXR8's Avatar
Pretty sure you hold down both the lock and unlock buttons on the remote at the same time (with all the doors shut) to set the keypad function. Indicators should flash when its changed.
KEVSXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2011, 07:58 PM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
With your remote, just keep your finger on the button and the locks will open .IE, press the button and keep it pressed and the drivers door opens then a second later the rest will open......... or do as KEVSXR8 says and hold both buttons down till the lock function cycles to open all 4 doors at once.
Bushbasher
MINE- AUII Forte
