Old 06-08-2011, 11:03 AM   #1
bunter
F.T.F Member
bunter's Avatar
Default Cougar Headlights
just wanting to know if anyone had fixed the dulling lens problem, and what did you do and what did you used to clean them up and what glue did you used to stick the lens back on?.
as the headlights in the wife cougar are dull and its not the globes.
Family Stable
Dark Green EF Mont (The Green Meany)
Lightening Strike 2004 TS Territory
Old Rides
White V8 EB Mont
Ebony Black 2000 V6 Ford Cougar
bunter is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 10:19 AM   #2
thearrow
Default Re: Cougar Headlights
Good to see you back bunter. Headlights are an issue and there is no real quick fix.
Did you get your ECU fixed OK in the end ???
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2011, 11:20 AM   #3
MAD
Petro-sexual
MAD's Avatar
I use this method.
http://www.autogeekonline.net/forum/...lant-idea.html
- The Story
Old 08-08-2011, 12:21 PM   #4
bunter
F.T.F Member
bunter's Avatar
turned out to be the ABS module the ******* that shorted out the wires while the car was ign on blew the ABS trying to install the footwell lights and they said they didnt do it had to get fair trading in on it and they stuffed around then fair trading steped in told them to get there *** in gear and fix the problem.
then they delaid fixing the car it was in and out of ford at smithfield, as thats who we said we would only send our cougar to, and the assholes tried to do a dodgy and get there guy to fix it, they end up fixing it after a while and coped a fine for stuffing us around, thats one up for fair trading
spoke to the guy at pontiworld he has kids but said use what ever people use to polish up headlights on the EF/el fords so need to see what works and what dont
Family Stable
Old Rides
White V8 EB Mont
Old 09-08-2011, 05:33 AM   #5
REDDYZ
REDDYZ's Avatar
I have used the one available from Autobarn and its quite good as long as you follow instructions properly and do it with lot of patience and with consistency as Cougar headlights are quite big and has uneven surface. Kit costs $39. I dont remember the name but there is only one available in Autobarn store. Am currently overseas, once am back I can give u the name. It has some 5 or 6 types of sand papers and as long as you follow instructions carefully and do it by hand, you will be able to achieve close to factory condition.
PS: With this kit, until u finish the last step you dont see the actual result. Dont give up inbetween.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
