Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 30-06-2011, 09:12 PM   #1
wogrocket
HKS T51R SPL
wogrocket's Avatar
Default 4 piston rear brembos ???
Just wondering if the sedan and the ute use the same 4 piston brembo caliper with just different mounts as I got a pair of calipers with mounts off the sedan
and if they are the same would you have the mounting brackets off a ute I could do a exchange with and give you $$ as well
Cheers Mick
it: TTG 12.365 @ 111.97MPH tuned by Dave @ CPV ph 0407749043
2SCARY Supra 903 rwhp featured in QCS issue 3 & performance imports issue 144 also tuned by Dave Sheehy
GET UP A Datto 1200 ute power coming soon
WOG 11 Ba Persuit ute turbo 568 rwhp 6psi boost on bp98 Tuned by Dave @CPV featured in Street fords issue 121 http://www.fordforums.com.au/showthread.php?t=11354035
wogrocket is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2011, 10:18 PM   #2
wogrocket
HKS T51R SPL
wogrocket's Avatar
Default Re: 4 piston rear brembos ???
heres some pics of the calipers I have if it helps
Mick
Old 01-07-2011, 12:59 PM   #3
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The calipers and brackets should be the same whether it is ute or sedan although the brake hoses will be different. The utes did not have brembo's fitted after the BA's because of pad knockoff and the only other thing is the caliper would sit in a different position from sedan to ute although the bracket would be the same .
The brembo brackets from memory were a cast type and not a aluminium one like you have there.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 01-07-2011, 04:15 PM   #4
wogrocket
HKS T51R SPL
wogrocket's Avatar
Yea not sure if these came off a bf or fg
Also what's a pair of slotted rear rotors worth and brake lines
Cheers Mick
Old 01-07-2011, 05:51 PM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Cheers Mick
DBA 4000 Slotted pair plus rear braided lines are $660 if it has traction control or $700 if it doesn't thanks
MATTHEW PEARCE
Phone 02 9609 1101
