Old 05-06-2011, 04:19 PM   #1
somers181
somers181's Avatar
Default Induction/Inlet manifold small hole
Hi, I am in the process of rebuilding my 1500GT motor for a Consul Capri and while cleaning the inlet manifold noticed a tiny hole on the underside that loks like it should have a small screw or air hose attached.
Does anyone know if this should be blocked off or if it should have a hose attached to it???
Any assistance would be appreciated,
thanks, Rick....
Capri Car Club of NSW,
Keeping the Legend Alive since 1985
somers181 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2011, 04:38 PM   #2
caprispecial
Default Re: Induction/Inlet manifold small hole
Most of these have probably broken off by now, on my 1500gt cortina it is a fine hollow steel pipe which is about 150mm long and aims at the crossmember. I havnt seen it working but I presume that its an over flow pipe to direct excess fuel out without dumping it all over the extracters, a problem peculiar to non cross flow engines.
caprispecial is offline   Reply With Quote Multi-Quote with this Post
