Looking for info to replace horn switch on au. Under air bag on steering wheel
What do you need to know ?
I think the horn switch is in the air bag assembly and uses the clock spring setup on the column.
AU XLS. |
Horn button is part of the airbag assembly. If your horn isn't working, check the fuse first.
Fuse ok
