Old 31-05-2011, 09:05 PM   #1
simonr23
Default cost for recon auto trans
i think my auto trans is dying on me, and i'm wondering what sort of cost i'm up for, to have it replaced. either 2nd hand, or a reco unit.
thanks for any info you can give.
my car is an au series1, if that matters.
simonr23 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2011, 09:46 PM   #2
Ford Falcon XR6
Ford Falcon XR6's Avatar
Default Re: cost for recon auto trans
Couldn't help you on the price of a reco box but what is the reason that makes you think the box is on it's way out there are prently of easy fix soloutions to problems that could resemble a worn gearbox such as low fluild or dirty fluid or filter.
Cheers Lorenz
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2011, 09:51 PM   #3
macman
macman's Avatar
I was quoted $2500-$3000 for a full rebuild. Perth prices though. A 'good' second hand box I was quoted $500 (plus fitting).
macman is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2011, 09:59 PM   #4
simonr23
thaks guys.
the trans wont lock up the TC in 4th under any load, but is always locked up when i'm off the throttle (in 4th) causing very annoying issues when coasting down hills.
it slips into an 'angel gear' on gentle, cold take offs before lurching into a wound up, tyre chirpling, low throttle % take off, the last 3 days, and it hates to kick down, very severe (no feeling of slip/easing into the lower gear)
fluid is full, and actually in decent nick(certainly not browning, or smelling too bad suprisingly)
i thought for a while that it was a computer issue, as it's had the reverse TC issue in 4th, for ages, but the take off issues have me almost certain it's hardware related.
thanks again for any more help.
Old 31-05-2011, 10:37 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
How long since you had the oil and filter changed ?
Old 31-05-2011, 10:44 PM   #6
simonr23
about 20k. when i got the car it was doing the 4th gear thing, so i replaced fluid first, didnt fix it, but apart from being rough on downshifts, (also when slowing down to a stop- the 3-2, 2-1 shifts can be abrupt, only 1 out of 20 times or so)
filter, i don't know. the shop just did a fluid replace, as far as i remember.
Old 31-05-2011, 10:54 PM   #7
bodes-sh
i'd get it serviced. the issues you are having when cold sound like low fluid. get them to do a full fluid flush, new filter and check all the solenoids. it sounds like its still got some life left in it yet. how many k's on the car?
Old 31-05-2011, 10:55 PM   #8
GasoLane
Former BTIKD
GasoLane's Avatar
Did you see how they did it?
They should have taken the the sump off of the Auto and then staring them in the face is a filter!
Old 31-05-2011, 11:15 PM   #9
03 GHIA
Had mine done a few years ago, full reco was 2k from APS with 3 year warranty. Does it play up only when hot/cold?
Current
Viper 2010 50th Anniversary XR6T
Stock, but for how long...
Previous
White 2003 Fairmont Ghia
First- RIP.
White 1990 Ford Fairmont
Exhaust, intake, cam & lowered.
03 GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2011, 12:40 AM   #10
InfernoSR
Sales Representative
InfernoSR's Avatar
been quoted 2.5k for reco, or an exchange for about 1.6k
Old 01-06-2011, 10:15 AM   #11
GasoLane
Former BTIKD
GasoLane's Avatar
Um, I thought this was the same thing...ie: Any exchange unit is a reconditioned one.
Old 01-06-2011, 11:10 AM   #12
GK
Walking with God
GK's Avatar
Fluidrive in Coburg quoted me 1.8 thereabouts a few years back, for a reco exchange unit.
Dino is a good guy too, really knows transmissions and takes the time to explain things properly.
If mine needs work, he's the only place I go.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 01-06-2011, 12:35 PM   #13
bodes-sh
sort of. reco would be pull yours and send it away to get done. (unless they do it in house) that way you are keeing your own trans.
exchange would be pull yours, put in an exchange one and then send your old one back to the exchange place. the only problem is you may get stung if yours has busted bits and is in bad condition for an exchange unit.
the price difference would come down to labour costs, stripping and refitting all of yours versus just changing the unit over. exchange ones are still reco, but because the exchange places don't have to remove and refit to the car it is cheaper.
otoh, for 2.5k you could almost get a built one these days....
Old 01-06-2011, 12:36 PM   #14
macman
macman's Avatar
Possibly the difference between having your original box rebuilt or having a pre-rebuilt one pulled off the racks and installed. I expect there's more time in the workshop for reconditioning your original box rather than just swapping in another box that's already been done. Depends who you go with as to how they operate.
EDIT: yep what he said (above).
Old 01-06-2011, 02:59 PM   #15
FGII-XR6
FGII-XR6's Avatar
better to get yours done you might get out of it for under 1K depending on how bad it is and whats needed
[SIGPIC][/SIGPIC]
Rides:
Old 02-06-2011, 05:14 PM   #16
simonr23
Thanks again guys. It hasn't slipped or done anything weird since I posted. Still severe on accel downshifts and won't lock the tc in 4th. Any ideas on what that could be. It does lock when coasting and once below 1700rpm will downshift to 3rd
Old 09-06-2011, 12:20 AM   #17
03 GHIA
What speeds do you normally travel at? I know that my converter doesn't lock if i have the A/C on and travelling under 70, if the A/C is off it's normal. Not sure if that's what it's meant to do but its never bothered me.
Current
Previous
First- RIP.
Old 09-06-2011, 12:59 AM   #18
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
was quoted $1800, $1900 OR $2000 with 1, 2 and 3 year warranties respectively from a place in Vic last week. Price variance was due to the parts used to rebuild, going from 'ok', to 'moderate' to 'genuine ford'.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
