Old 23-05-2011, 03:10 PM   #1
GS608
Default p/s high pressure fitting
Hey fellas. I'm attempting to change the nut on the high pressure line, called up Ford and they note that there are two different types, one for early builds (which is $20) and another for later builds (which is $14) Anybody able to share info on what changed with the fitting? I have a MAY 99 build which according to Ford requires the early type, like everything AU 1 many parts seemed inferior and were upgraded, is it possible to use the later fitting?
Old 23-05-2011, 03:43 PM   #2
el_wagon
el_wagon's Avatar
Default Re: p/s high pressure fitting
Probably not, it's a big conspiracy to make you pay an extra $6 and last 50,000klms less.
el_wagon is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 05:47 PM   #3
GS608
ah not fussed about the price..just wondering if its a superseded part..ie not going to start leaking on me again in a week or two.
Old 24-05-2011, 12:07 AM   #4
irdonn
irdonn's Avatar
Hi mate.
I've got a spare one for a series two XR8. If you find out they're the same I can post it for $10 to your door. Maybe check with Zane from Southside Ford who are a sponsor here.
Cheers,
Ian
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2011, 11:37 AM   #5
GS608
Cheers for the offer mate, but turns out you can't use the later fittings, the early ones were just a nut and the pipe pokes out the end, where as the later fittings are all one.
Old 24-05-2011, 05:43 PM   #6
irdonn
irdonn's Avatar
I just have the nut to suit the series two from the power steering pump end.
http://www.fordforums.com.au/showthread.php?t=11330416
Was this what you were looking for 5.0? It connects to the hose with a circlip.
06/01 AUII XR8
Old 24-05-2011, 06:37 PM   #7
Papa Smurf
Papa Smurf's Avatar
The later Fitting BA 3F656 B WILL fit your AU pwr strg hose no worries, you just have to hacksaw off the old fitting and out the NEW one on, much better too.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2011, 09:45 PM   #8
GS608
PANUP, the early fitting ends just after the thread in your picture, its about half the size, should have taken a picture of it. Unfortunately already purchased the part earlier this morning, was told by the spares bloke that there is no way the later fitting will fit.
Old 24-05-2011, 10:22 PM   #9
irdonn
irdonn's Avatar
No probs mate.
06/01 AUII XR8
