15-04-2011, 03:45 PM | #1 | ||
AULTD
I am having a problem with the LTD ( AU series II ) V8
The coolant is being pushed out the overflow hose whilst driving down the road. It is not overheating and does not do anything at idle. I have replaced the cap but this has done nothing to solve the problem. I did have trouble with the heater tap recently and had to replace it. I have read that you need to bleed the system which I think I have done by leaving the cap off and running at 2000rpm for 10 mins. All hoses are hot to touch so I presume the coolant is circulating correctly. How do you know if it is a head gasket problem or just an air problem? The car is running O.K. with a slight miss at around 100kph. |
15-04-2011, 05:06 PM | #2 | |||
AU DIE HARD
Sounds nasty Pete could be the head gasket has gone between a water jacket and the cylinder head, may need to get the cooling system pressure tested, and a Comp test on the cylinders done to check for any surprises
15-04-2011, 05:40 PM | #3 | ||
AULTD
I will do a compression test tomorrow to see if that will tell me anything.
Will the plugs have any indications so that I know what side it is? It is rather strange that it only empties the coolant bottle with the pressure. The car is definitely not overheating at the moment. I think you can get a cooling system check that checks for combustion gas in the water so this might be my next step. I don't really want to drive it too far at this stage. |
15-04-2011, 06:12 PM | #4 | ||
Yeah mate any decent mechanic can perform that test for ya i looked into buying a kit when I had headgasket issues with my eb xr6 I had the test done but it showed nothing.
But when starting and running the car the cooling system almost pressurised from start up indicating a combustion leak. Also a good test that a mechanic can do for you is to leave the cap off the radiator and just put the gas analyzer probe over the filler neck on the header tank if any gasses start to show up on the gas analyzer means you got a combustion leak. |
15-04-2011, 10:55 PM | #5 | ||
The new cap, it is the right type? A non-recovery one?
16-04-2011, 12:39 AM | #6 | ||
sounds like either a head gasket cracked head or coroded water jacket you'll need to rip the heads of regardless for these things
[SIGPIC][/SIGPIC]
16-04-2011, 07:34 AM | #7 | ||
Is the engine missing at idle? Does alot of vapour come out of the exhaust pipe on start up?
16-04-2011, 01:45 PM | #8 | ||
AULTD
Took all the plugs out this morning and nothing seems abnormal.
Tried to do a compression test but my compression tester doesn't fit in the small plug holes!!! There is no indication at idle of a miss and no extra vapour coming from exhaust on start up. It seems to pump the water out once it gets up to operating temp and only while driving. Doesn't do anything when warmed up and idling with full expansion tank. The new cap I bought was the one specified for the AU V8. If it is the head how will I tell which side it is? Thanks for all those that have posted. |
16-04-2011, 05:39 PM | #9 | ||
Mate sounds like you didn't get all the air out
I think there was a bloke on here that had the same problem with an nc v8 lane try doing a search for the thread he had the same dramas but turned out he didn't get all the air out properly. I'm thinking of getting one of theese myself its an airlock eliminator http://cgi.ebay.com/ebaymotors/U-Vie...item35b0da2492 |
16-04-2011, 06:14 PM | #10 | |||
AULTD
Maybe they sold me the wrong cap. I will be pleased if it turns out it is only the cap. Will buy another one tomorrow. A neighbor had a pressure tester and the system is holding pressure so he doesn't think it is a head gasket. |
16-04-2011, 06:44 PM | #11 | ||
sounds like it might be the go.
not sure what brand you got, but according to the tridon website there are 2 different listings CA20135 which is the equivalent of the one you were given (the recovery type) and CN20135 which is the non recovery type, which is the one you need. as i said, these are just off the tridon site, but i'd say different brands would be the same |
16-04-2011, 07:21 PM | #12 | |||
17-04-2011, 05:13 AM | #13 | ||
Fantastic Plastic
If it isn't the wrong cap !.......I had the same problem once (not in an AU) , but it just ended up being the thermostat was jamming, not not opening now and then and causing the radiator to overheat a tad and pressurise and dump it out of the overflow now and then, maybe just need a new thermostat ??? maybe ? , cheers.
17-04-2011, 03:19 PM | #14 | ||
AULTD
Thanks for all the replies.
I went to Bursons this morning and asked for a cap. The sales guy looks in the tridon book and says there are 2 listed for the AU, a recovery and non recovery one. I said I will have the non recovery one which was the sum total of $5.95. When I bought the recovery one from autobarn the guy there didn't ask me what type. I wonder why they have both listed. I thought all the AU's had header tanks and so would be non recovery type. I haven't taken the LTD out for a spin yet but I am hopeful that this will fix the problem. It is certainly a trap for the unwary as I didn't realise there were 2 different types of radiator caps!!!! Thanks again for all the help as I was resigned to the fact that the head had blown a gasket. |
17-04-2011, 06:55 PM | #15 | |||
18-04-2011, 09:00 PM | #16 | ||
Smile
If you dont have success then get the water system pressurised. I blew a little hose last week and my first thoughts were head gasket too. That test will show a leak
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
18-04-2011, 10:23 PM | #17 | ||
AULTD
Took the LTD for a 20km run with the new cap on and the water level dropped a little but at least it didn't push it all out the overflow.
Hopefully this has fixed the problem. All I need now is a new exhaust system and a leaking pinion seal fixed. |
18-04-2011, 11:10 PM | #18 | ||
The level might drop a little as it works any air bubbles out of the system. Give it a few days. I put a pencil line on my reservoir, makes it easy to see if level has changed.
21-04-2011, 10:13 PM | #19 | ||
AULTD
The new cap slowed down the amount of coolant loss but on a trip of about 100km it drops to about half way.
The next trip it dropped to about a quarter and the low level warning light comes on. I put a bottle under the overflow hose and it is definitely coming out the overflow. The car runs fine with acceleration etc but has a slight miss when accelerating from 100kmh. |
27-04-2011, 12:15 AM | #20 | ||
Might have to check for exhaust gas in the coolant. Or maybe its like XR6-VCT-2000 said.
30-05-2011, 08:39 PM | #21 | ||
AULTD
Just an update on the LTD.
I replaced the thermostat and hoses and the water level has not moved off max for the past 2 weeks. It looks as though the old thermostat was only opening just before boiling point and so causing pressure in the system and pushing it out the overflow pipe. I also pulled the gas convertor out and look what was inside!! I have changed the convertor for a new one and this has now fixed my miss at 100Kph. I think the car was starving for fuel!!!! I now have a squeal on start up that is coming from the synchroniser so I have ordered one from Rocket in the USA. I now need to replace the exhaust system as the two centre mufflers have rusted out. |
30-05-2011, 08:49 PM | #22 | |||
AU DIE HARD
Sounds like your having as much fun as me Got a mate that can do a Zorst system at the rite price Pete send me a PM if you want more info.
12-06-2011, 11:30 PM | #23 | ||
AULTD
It's all fun and games.
Thanks for letting me know about the exhaust place. The new synchroniser came from Rocket industries in America 5 days after ordering it. I replaced it today ( easy job ) the longest part of the process was removing the coils to access the synchroniser. The old one was certainly had it as it squeaked like mad just when turning it by hand. Has anyone pulled the synchroniser apart and replaced the bearings? If so where did you buy the bearings and how much were they? How hard a job is it. I realise the small pins have to be knocked out and the beveled gear has to be removed. Do the bearings then come out with the shaft or do you have to pry them from the housing. |
08-03-2012, 12:00 AM | #24 | ||
not here much anymore
I'm digging up an old thread here but the XR8 is having the same coolant issue - no leaks, new thermostat but losing coolant at a fairly rapid rate. I am 99% sure the cap I got was the recovery type so I will change it for the non recovery and see how that goes, other than that got no idea. No milky oil etc either.
RAM 1500
08-03-2012, 10:21 PM | #25 | |||
AU DIE HARD
Chuck a coke bottle on the over flow (like at the drags ) and see if it's filling it, that way at least you eliminate 1 more source .
08-03-2012, 10:46 PM | #26 | |||
RAM 1500
09-03-2012, 02:16 AM | #27 | ||
AULTD
Mine took a bit to settle down but it is now not using any coolant.
The different caps are certainly a trap. Good luck and I hope it is just the cap. |
09-03-2012, 09:38 AM | #28 | ||
I was having a similar issue, turns out I was simply over-filling the overflow bottle. Was used to the 4L where you could fill it up to the brim and it would stay there. Re-filled the bottle on the 5L to about 3/4 and hasnt budged since.
Food for thought.....
Current Ride: EL XR6 - 4.0, M5, FULL EXHAUST, 18” ANZ TYCOON'S, SUPERLOWS Former Rides: EB1 FAIRMONT – 4.0, A4, FULL EXHAUST, WADE 1004, TIP J3, 18” BA XR8’S, SUPERLOWS, SPRINT KIT, AU1 FAIRMONT GHIA – 5.0, A4, 3" CATBACK, 20" VERSUS WRAITH, ULTRALOWS, TICKFORD & MOMO GOODIES |
10-03-2012, 08:23 PM | #29 | ||
5.6L x 2 pilot
Hi peterban. First AUII LTD other than mine that I have seen (or heard about) on here. Aren't they an awesome car. Would love to know more. What is the build date of yours? Russellw informs me that there where only 100 made in 2002. Any pics of yours? I am the owner of au2ltd.com if you are interested in checking mine out. Would love to host some pics of yours too if you are keen.
Well done on sorting out your issue. Trying times. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
11-03-2012, 06:34 PM | #30 | ||
Peterban....
In response to your question re the bearings for the syncronizer, there's a chain of outlets known as "Consolidated Bearings Ltd" that has a bearing for anything, and I mean anything, give them a try, make sure you take a sample bearing for sizing. 4ford |
