Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 10-04-2011, 05:59 PM   #1
ossie cossie
Question FG F6 4 pot brembos?
What is the minimum thickness that i can go on these disks. At the moment they are 30.89mm Can i giv them a skim? i also need pads. is it worth getting a skim and then replacing the pads or is it more cost effective to just put new pads in for now and then get new rotors and new pads again when they get to there minimum width?
Thanks in advance.
Tony.
PS it is on 38,000kms at the moment.
ossie cossie is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2011, 10:27 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: FG F6 4 pot brembos?
Thanks in advance.
Tony.
Hi mate as i can't see the rotors i can't confirm that fitting them with new pads is the way to go as they normally have an uneven wear and also a lip on the rotors edge. The minimum thickness is 30mm so the machinist could determine if they will take a machine. Front pads are from $185 a set and front slotted rotors from $600 a pair. If the front rotors are 30.75 and the face of the rotors is quiet even then pads could be fine for now but again as i can't see them i can't confirm sorry.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 20-05-2011, 01:13 AM   #3
ossie cossie
Question Re: FG F6 4 pot brembos?
Thanks mate are the pad part numbers, DB1935
Is the $185 include postage to Perth WA?
FLOORED if i were to give you some AP disc rotor part numbers and sizes would you be able to give me a quote on them?
Regards.
Tony.
Old 20-05-2011, 09:58 AM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Regards.
Tony.
are the pad part numbers, DB1935 - I quoted on hawk ceramic low dust pads for you as that number in bendix is only available in the SRT compound.
Is the $185 include postage to Perth WA? $15 Freight for 1 set of pads
FLOORED if i were to give you some AP disc rotor part numbers and sizes would you be able to give me a quote on them? Yes
MATTHEW PEARCE
Phone 02 9609 1101
