05-03-2011, 09:12 PM | #1 | ||
I have the haynes manual for the year earlier model and the egr valve they picture cant be found on my car.
Anyone know w here they are located on my model? There is something that looks suspiciously like it to the left of the throttle body but there's no electrical connector on it and the pipe runs all the way under the fuel injectors down underneath the passengers side somewhere? I will try and get pictures. |
05-03-2011, 10:34 PM | #2 | ||
Finally rollin on 20's
What engine do you have?
1.3 or 1.5? From memory aren't the 1.3 semi carby fed? and the 1.5 efi.
Fiesta ST..... Colorado Red...... SOLD Territory Turbo Ghia ..... Winter White SOLD - Good bye my little buddy!!!! K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs. |
06-03-2011, 11:13 AM | #3 | ||
Yes 1.5, it is EFI.
Here's a shot of my engine. |
06-03-2011, 08:50 PM | #4 | ||
Isn't the egr valve the bronze circular looking thing just to the right of the inlet manifold, where all the tubes go in too!!
Maybe your car has had an engine swap!
06-03-2011, 09:09 PM | #5 | |||
(Suits models with Ford EEC-V Management System) Go To: INDEX Go To: COMPONENT LOCATION Copyright Ó AUTO-TECH Index Adaptive Idle Control 4 Fuel Injectors Air Conditioner Compressor Relay Fuel Pressure Air Conditioner Condenser Fan Relay Fuel Pressure Regulator Air Conditioner Defroster Switch Fuel Pump Air Conditioner ON Switch Fuel Pump Relay Air Conditioner Pressure Switch Fuse Locations Automatic Transmission Gear / Neutral Switch (Manual) Barometric Pressure Sensor High Tension Leads Camshaft Position Sensor Idle Air By-Pass Screw Canister Purge Solenoid Idle Air Control Valve Clear Flood Mode Idle Speed (Base) Clutch Pedal Position Switch (Manual) Ignition Coil Crankshaft Position Sensor Ignition System 1 Diagnostic Connector Ignition Timing (Base) 2 Distributor Inhibitor Switch (Auto) ECM Intake Air Temperature Sensor ECM Relearn Procedure Kick-Down Solenoid (Auto) ECM Voltage Table Kick-Down Switch (Auto) Electrical Load Input Main Relay Emission Schematic Mass Air Flow Sensor 3 Engine Coolant Temperature Sensor Octane Adjust Connector (If Fitted) Engine Cooling Fan Relay Overview Engine Speed Limiter 5 Oxygen Sensor (Heated) Failure Mode Power Steering Pressure Switch Fault Codes Tachometer Signal Fault Code Erasure 6 Throttle Body Fault Code Extraction Throttle Position Sensor Fault Code Table Vehicle Speed Sensor Firing Order Wide Open Throttle Check Flash EEPROM Wiring Diagram Nothing listed for the 1.5 ??? But i have this for the 1.3... EGR System The EGR System (If fitted) recirculates a small amount of exhaust gas into the Intake Manifold to reduce combustion temperatures and reduce NOx Emissions. The System consists of: 1. The EGR Control Valve 2. The EGR Valve Position Sensor 3. The EGR Vent Solenoid Valve (3 Hose - Normally Open) 4. The EGR Vacuum Solenoid Valve (2 Hose - Normally Closed) 5. The ECM and it’s Input Devices The EGR operation is controlled by the ECM’s actuation of the EGR Vent Solenoid Valve and Vacuum Solenoid Valve to control the EGR Control Valve. It is monitored by the EGR Valve Position Sensor. When the Engine Coolant Temperature is less than 55°C, during Idle (Idle Switch ON), Deceleration, High Speed (Above 5,500 RPM) and Heavy Load, the EGR operation is suspended. When the Engine Coolant Temperature is between 55°C and 60°C and during Acceleration. the EGR operation is reduced. To Test: Exhaust Gas Recirculation (EGR) Solenoid (1.3L Engine Only) The EGR Solenoid Valve is located centrally on the firewall. The ECM actuates the EGR Solenoid with a Duty Cycle signal. To Test Voltages: See ECM Pin #49. To Test Solenoid Function: Disconnect the wiring connector and vacuum hoses • Verify that air will flow through the valve from A to the air filter. • Verify that air will not flow from A to B. Apply battery voltage across the terminals. • Verify that air will flow from A to B. • Verify that air will not flow from A through the air filter. Last edited by Road Games; 06-03-2011 at 09:29 PM. |
06-03-2011, 09:11 PM | #6 | ||
Sorry mate the program wont let me cut and paste pics .. but i cannot find it either ?
07-03-2011, 10:11 AM | #7 | |||
The error code it threw was for the 'idle control solenoid valve'. The engine would also not start with it unplugged. Indeed its possible it had an engine swap. Weird situation. Last edited by mr-fusion; 07-03-2011 at 10:31 AM. |
