ROCKING THE EL FUTURA
guys are the ba sway bars bigger than the au11 ones and if so do they fit the au11..
thanks heaps. Gotta get the car ready for AFD
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
Resident AFF detailer
Pretty sure the Whiteline code for front swaybar is the same for BA and AU models? Would be the same size then??
Same front bars will fit AU and the other thing. The only difference was between models. T-Series had fatter bars than Forte for example.
Stock front sway bar across the range is 26mm, and i think the T-series cars had a 29(?)mm front, can't remember the rear sizes off the top of my head.
****el's drive Rotaries, Four in-line is a waste of time, Six in-a-row just won't go, If you really want something great, drive a great big Ford V8! God made Holden's to keep w*****'s out of Ford's, and yes I'd rather push my Ford than drive a Holden! |
I thought stock front was 22mm, you can only get Whitelines in 27mm or 30mm?
Stock rear is 20mm? And you can get a 22mm Whiteline for the rear?
RIP...
Front series 1 was 27mm and series 2/3 were 24mm, which are the same as BA/BF.
. Oval Everywhere... |
ahh ok better of going whiteline.
Hi Guys
dave93761 is correct with the sizes, I have just replaced mine with whiteline front and rear, only problem now is big over steering. Any ideas? Chalky |
rexnet
to stiff in the rear. or get a stiffer front. also play with tire pressure a bit
![]() ![]() I have 27mm adj front and 22mm rear and it has transformed this taxi... |
