Old 06-11-2010, 05:21 PM   #1
DZFord
DZFord's Avatar
Default Whiteline Swaybar Installed
Took advantage of a spare weekend and some nice weather and installed a whiteline rear sway bar today (22mm, non-adjustable).
Overall, it's not a bad job to do, especially with the help of a mate or two. I followed the guide posted on the XR5 turbo forums here: http://www.fordxr5turbo.com/forum/in...ic,7256.0.html
Thanks to the original author.
The only real problem was a siezed nut on the left connecting link. We actually had to take the whole swaybar-conn.-link off the control arm, then remove the nut.
Jacking points are really important. Make sure you use a block of wood just adjacent to the sills, with jack stands:
Old vs New:
Installed pic:
I took it for a quick spin afterwards and I was very happy. Put me down as another forum member who says that this one of the best bang for your buck mods around.
Old 06-11-2010, 05:24 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
I have the adjustable varient in my XR5T they definately work wonders over the factory ones
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 06-11-2010, 06:15 PM   #3
casabonka
You can call me Chris
casabonka's Avatar
it is a good mod for not many bux..
I found it easier to do with the rear wheels on ramps.
oh and nice weather... its crap in sydney!!!
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2010, 09:43 PM   #4
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
I bet you wanna take it for a spin in the dandys now?? did you go for the 22" or 24" one??
I did the fronts as well and put an adjustable on the rear. 24" all round. I noticed more of a difference with the sway bars than I did when I put in the coil-overs.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2010, 12:47 PM   #5
DZFord
DZFord's Avatar
The weather was good yeserday, not so good today!
I got the 22mm swaybar.
Old 07-11-2010, 10:37 PM   #6
ah-see
i also got my 22mm whiteline read swaybar installed a couple weeks ago and i am also very happy with it
ah-see is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2011, 07:17 PM   #7
In Focus
Default Re: Whiteline Swaybar Installed
So I've developed an intermittent thump which seems to be coming from the back of the car (I'm almost deaf in one ear, so it's hard to pinpoint, especially as sound seems to carry through the car in these situations). Not all of the time, not over every bump, but I think it's when only one of the back wheels is going up or down relative to the other. It sounds like something whacking the car. I haven't touched the spare wheel stuff lately, and I shifted things around in case that was the problem, but it doesn't seem to be.
My first instinct was either the lowering springs or swaybar I had fitted recently, particularly the swaybar. When I checked the fittings I noticed a nut on the right side, a nut that gets screwed onto a horizontal bolt, if that makes sense - you can see the LHS one in DZ's pic, right at the top left with yellow goo on it - isn't super tight. I tried tightening it, but it seems to go round and round without getting much if any tighter.
Two questions.
1. Could the swaybar be the source of the thump?
2. Do the nuts need to be really tight? It doesn't look like it's going to come off anytime soon, but I'm wondering if it needs to be tight enough to stop anything shifting around, whether or not it causes thumping.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
In Focus is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2011, 09:01 PM   #8
marg99
Cannot recall what the mounts are like on focus rear sway bars but on the falcon they have links between sway bar and suspension like two little knuckles. If one goes it makes a clunk sound on bumps. Unless the top shocker mount is loose that the most likely cause.
Old 04-12-2011, 10:39 PM   #9
DZFord
DZFord's Avatar
Two questions.
To tighten that nut you'll need to insert an allen key into the end of the bolt part first to hold it still. Have a look at the end of the thread and you'll see where the allen key will fit (it is partly visible in that above pic).
Old 04-12-2011, 10:51 PM   #10
Russ
Russ's Avatar
You would be meaning where the yellow arrow is pointing ?
Old 04-12-2011, 11:05 PM   #11
sysh
A few screw loose
.. where did ya get the Whiteline sway bar in Vic?
sysh is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2011, 11:25 PM   #12
DZFord
DZFord's Avatar
From the whiteline website!
And spot on Russ, exactly where that yellow arrow is pointing. Thanks.
Old 05-12-2011, 12:29 AM   #13
In Focus
Thanks, boys. I didn't realise Ikea made swaybars!
Old 05-12-2011, 09:08 PM   #14
In Focus
Turns out the the bolts on the brake calipers were loose. The thing is, the brakes haven't been touched, unless it was at the last service - back in June...
Old 05-12-2011, 09:19 PM   #15
Russ
Russ's Avatar
That's a bit of a worry
Old 05-12-2011, 11:34 PM   #16
In Focus
Indeed. The funny thing is, I'm hoping it was someone's negligence. The alternative is that the things worked loose all by themselves.
Old 06-12-2011, 09:04 AM   #17
Russ
Russ's Avatar
I once had a front wheel leave me on a FWD car '79 Subaru wagon, it would appear that the tyre fitter who'd put my new tyres on a couple of weeks earlier got sidetracked and forgot to tighten the wheel nuts. Needless to say the car felt a bit weird for a while and I couldn't work out where this strange noise was coming from until the front wheel came off and I watched it roll past me in the opposite direction Surprisingly it caused no real damage, I gathered up the wheel nuts I could find (3 of the 4 at least) chased the wheel back from down the road, jacked up the car, put the wheel back on with the remaining nuts, drove home, found a spare suitable wheel nut in the garage to replace the missing one and that was it all fixed I didn't use the same tyre place ever again though
Old 06-12-2011, 09:46 AM   #18
baxtc1
This could be a thread of it's own, I'm sure there are plenty of stories out there like that, I have a couple myself.
baxtc1 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2014, 06:26 PM   #19
dazFX
Originally Posted by DZFord View Post
Installed pic:
Is this clamp meant to sit flush against the car? I think the bushing whiteline supplied me is a bit too big, The car is a LV sedan.
Also I had to get the stabilizers from a wrecked mazda 3 because ford charge $160! for one!
dazFX is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2014, 06:58 PM   #20
pajoda
pajoda's Avatar
Now that's a thread revival
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2014, 07:57 PM   #21
dazFX
I bought one because of this thread : )
Ended up cutting around 2.5 mm of the bushing to make it fit
Old 30-06-2014, 11:08 AM   #22
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I got this on my car too, had my trusted mechanic install it.
He left one of the links loose...
I had to use whiteline rear links though, unfortunately they hang low as.
Old 30-06-2014, 12:29 PM   #23
DZFord
DZFord's Avatar
Damo, the whiteline links are height adjustable if they hang too low: http://www.whiteline.com.au/docs/ins...ides/Z5146.pdf
Old 01-07-2014, 07:42 PM   #24
Franco Cozzo
Thailand Specials
Excellent I didn't realise that I might have to adjust them a bit.
