Old 05-10-2010, 01:40 AM   #1
WAS 240
Blue blooded
Default ba xr6t exhaust banging
I upgraded my exhaust on my ba xr6t to an aps 3.5" staino single system but now when i hit bumps on corners the exhaust bangs and bashes everywhere, I dont kno if i need smaller rubber mounts or adjust it somhow??? I just thought aps where really good quality and where pretty good fitting
Turbo 4.0L
SS eater
BA XR6 Turbo 283.6rwkws
WAS 240 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 07:41 AM   #2
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
I assume you took back to the fitter for an explanation before posting here ?
Falcon Coupe is online now   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 10:10 PM   #3
WAS 240
Blue blooded
nag fitter is 2.5 hrs away in sydney so havent got back there
Turbo 4.0L
SS eater
Old 06-10-2010, 12:31 PM   #4
sleek7
When I had my 2.5" xforce cat back fitted, it started to clang on the pipes around the second muffler. Turns out the rubber holders at the *** end of the car had been a bit stretched and had too much movement on them. Had this resolved by putting, i think hose clamps? around the rubber holders to tighen the fitting up (cant think of what the clamp things are called). I can take a pic and post if you like.
sleek7 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2010, 02:59 PM   #5
Fev
Fev's Avatar
As long as it works well now and it's not about to snap off it should be fine. If it continues to happen get them to weld new exhaust mounts on which should be tighter
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
