Pro Street Au Ute
g'day all, i need some help with removing the fuel pump from my au ute. I've already taken the tub off and had a bit of a look before coming to work today but ran out of time. but in the manual it mentions a special tool to unscrew the fuel sender unit.
Does anyone know what this tool looks like or what i could make one out of or another way to remove the fuel sender unit. Any help would be great thanks. |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
At a guess it would be the same as the screw cap on the sedan removal of that is in this link
http://www.fordforums.com.au/vbporta...article&id=692 2 blade screwdrivers and a flat bar or another driver should do it
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#3 | |||
Pro Street Au Ute
It doesn't matter if it's different to the sedans. As Whoosha said two flat blade screwdivers with a bar between them will do the job - the best part is they won't cost you anything and they are "one size fits all".
if they are anything like the e-series i made up a quicky tool for the job,
Money Talks, but all i ever hear is it saying Goodbye!! |
Pro Street Au Ute
that tool looks good. My setup is a bit different screwdrivers will do the job i had a look today just a turn and release setup quick and easy. Thanks for your help guys.
ORSM Ford Cruisers
sorry for digging up an old thread but is there any way of removing the filler neck from the tank or is it definatly one unit?
having huge issues with mine as i have a gas tank in the way... so far i have had to remove: tail shaft, rear brake calipers, move diff, remove rear of exhaust and now remove the gas tank so i can slide it out. wish i had a hoist... is there an easier way to do it?????
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
Pro Street Au Ute
no mate you can't remove the filler neck from the tank. Its a crap setup for removing the tank but thats the way it has to be done as far as i know, it was alot less stuffing around to take the tub off to change the fuel pump. Why are you removing the tank i hope its not to change the pump?
The Ford dealer way to do it is to move the rear axle back so the tank can be dropped out.
The other way is to take the tub off and then remove some metal sheeting above the cap that holds the pump in and extract the pump from the top like this http://www.fordforums.com.au/showthread.php?t=11313390
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
take out liner and then remove the tub. i used my engine crane to lift of tub. i have since found that it wasn't my dash giving false readings on the fuel gauge and distance to empty (swapped dashes with my other xr8) so have to pull the tub off again.first time i cleaned and checked the sender and bent the little finger bits but it didn't help. can the sender be bought seperate to the pump because ford only sells the whole unit for $370
