td-76
looking into buying a 351 for a td cortina not sure wat type i need windsor or clevo??? got the mounths price from the rod shop now just trying 2 figure out if standard extractors fix on em in the td.
any1 got any suggestions? |
not really sure what u are asking here mate, i will try to answer ........ I lobbbed a cleveland into a cortina a while back, had to push the firewall back a couple of inches. xa - xc extractors fitted without a drama.even the sump was ok. I can only assume a windsor would go in just as easy if not easier....... does that help ?
Cheers Doc |
A Windsor is much much easier in a TD. And more room for a 'proper' extractor.
td-76
hey guys yee well i have herd its card 2 get extractors in em apparently i had to get them custom made.....i have bought the mounts for the v8. so i guess winsdor is the much as u guys are saying do i go 302 or 351???
02 or a 51 make no difference size wise mate, if u want engineers , i would hazard a guess u would only get a 302 engineered, im doin a capri right now for some stupid reason.......... and the engineer wouldnt allow a 351. if u just wanna take it bangin down the strip, do what u like . If money is a option like it is for most of us, use cast iron manifolds, a decent zorst man will be able to do a system to utilise them without the 1000 bucks cost of a set of custom headers. as for custom mounts, the corry i did, i just weled a plate across the originals and bolted the stock clevo engine plates to. custom nothing. ever since hadfield sold up.................. the new blokes are meh....
td-76
well i guess now i got the engine mounts so do with make do i guess....but appreciated ur help.....u know anything about diffs??? should i keep the original td diff will it hold lets say i do put a 302 with a cam 351 heads and a decent holley would it hold???? i gotta do brakes coz the corty brakes r ****!!!
if u dont dump it, the diff will hold for a while, it will have to be done eventually tho. a cheap way would be a v8 borg warner out of around xd era. may be a touch wide tho ?? anyone ? . as for brakes, like they say if ya gunna make it go, ya gotta make it stop.
td-76
ye thats rite been looking at brakes.....found some places that do them but not sure if they do 4 or 5 stud conversion.......then another issue tyre size wanna keep the original 13's with the hubcaps and whitewalls sleeper style
Mk2 Racer
Td Te and XF falcon diffs are the same width and both coil suspension shouldn't be too hard to just swap centres and axles
Les |
i would hazard a guess if u do a brake upgrade u will not be able to keep 13" wheels mate. 14" at a push, maybe even require 15". 13s are way off the mark.
td-76
ye i know they are off the mark but will see how we go i guess!!! now another question the cortina has been sitting for about a year.....took it for a drive the other day and my back breaks dont work at all what could be the reason front brakes work!!
#12 | ||
1. The rear slaves went to heaven ?
2. low fluid ? 3. need a bleed ? |
td-76
fluid is full so maybe slaves or bleed but handbrake works fine
#14 | ||
u melbourne ? might have a spare here. handbrake always gunna work , cable ....
#15 | ||
td-76
ye i am in melbourne much help would be appreciated
#16 | ||
hay mate did ya end up puting a v8 in the cordy?
