Old 14-07-2010, 01:15 AM   #1
Team Evolution
Default Power steering
Ok whats the go every other vehicle I or the wife have ever owned no matter what brand have had a power steering resivior that you could see easy to check levels and fill.
Now with the wifes zetec 2.0 liter I had to look in the hand book to even find the bloody thing.
So 1 how do you check the level then how do you fill it do you remove the front drivers head light or remove the inner guard on the drivers side .
Which dick of an engineer came up with this design
Duncan
Team Evolution is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2010, 02:23 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
What model car 2 litre Zetec are you talking about? I am assuming you're talking LR Focus? (Later Focus' have a Duratec engine)
In the LR Focus, the power steering reservoir is clearly visible at the back left hand corner (facing engine bay) of the engine
Have you misread the manual, or is it a different car? (OK, mine looks a bit different to standard, but the layout and position of the power steering reservoir is the same)
Old 14-07-2010, 02:37 PM   #3
marg99
Joys of earlier models!!! In mine( LT) the resevior and pump sit under the drivers side headlight which is fairly easy to remove. You just do not want a little bingle in the drivers side front or it all gets smahed to little expensive bits....
Old 14-07-2010, 08:48 PM   #4
Team Evolution
Believe its an 06 or 07 shes not home to ask think it is a duratec motor no hand book did show me were it is .Got to ask your self who in their right mind would put it were it is no way to check levels or fill it with out a bit of work .No other manufacturer that I have ever seen is this stupid.
So its out with the head light just to check the level heaven forbbid if it ever gets a small weep and needs topping up every few weeks.
Old 14-07-2010, 10:47 PM   #5
ptwhite2003
Default Calm down.
You seem slightly bitter over this little problem.
ptwhite2003 is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2010, 08:29 AM   #6
marg99
you all seem to miss the good news about focus electric power steering fluid holder placement. Ford does not expect the fluid to leak in LT onward models, hence no need to check its level, unlike other makers where the risk is so high they paint the lid yellow so you can find it easily in the engine bay.
Old 15-07-2010, 09:25 AM   #7
melbzetec
melbzetec's Avatar
OK. It's a Duratec engine not a 2 litre Zetec as suggested in the first post. that makes sense now
Old 16-07-2010, 09:31 PM   #8
Team Evolution
The point is the power steering light has been comming on infrequently of late I just want to check the fluid level something easily done in any other vehicle .
Im not a brand spercific person if you think Im a ford hater just like my vehicles made with the kiss theroy pardon for the spelliing.
Power steering along with brake fluid coolant level and oil level should be something easily checked every time you fill the vehicle with petrol .Just cant believe some tool of an engineer designed the car which is great this way.
So once again which is the easiest way to check fluid level and possibly fill it up
Duncan
Old 16-07-2010, 11:04 PM   #9
DZFord
DZFord's Avatar
Hi Duncan,
As marg99 mentioned, the LS-LV Focus is equipped with an Electro-Hydraulic Power Steering, and according to Ford, there is no requirement to check the fluid level. This is why it is buried deep down in the engine bay.
Unfortunately, the only way to check the fluid levels is to remove the headlight...a pain in the a$$.
Old 18-07-2010, 12:48 AM   #10
Team Evolution
Thanks so if the fluid level is fine any ideas why the light comes on at different times steering still feels the same wether the light is on or off.
Could it possibly be an electronic problem if so any ideas.
Old 19-07-2010, 10:48 AM   #11
DZFord
DZFord's Avatar
I know this sounds stupid, but in your case, I'd still remove the headlight and check the fluid levels. There could be a slight leak anywhere in the system.
Old 20-07-2010, 01:28 AM   #12
Team Evolution
Will pull out head light this weekend to check fluid level
Old 20-07-2010, 07:38 AM   #13
20focus05
I wanna XR5
20focus05's Avatar
Its below Driver side headlight
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
