01-07-2010, 07:53 PM | #1 | ||
Any size difference from au s/3 forte to xr series stabilizer bar diameter . ?
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
01-07-2010, 09:03 PM | #2 | ||
The only thing u'll see!!
Don't waste your time, go for 30mm adjustable whiteline in front and 22mm in rear.
01-07-2010, 09:30 PM | #3 | ||
not sure what forte size is, s2 xr is 24mm.
01-07-2010, 10:34 PM | #4 | ||
cheers , yeah measured mine 24mm
02-07-2010, 08:53 AM | #5 | ||
Anyone know the diameter of the rear bar in an AUII forte
02-07-2010, 07:45 PM | #6 | ||
"not sure what forte size is, s2 xr is 24mm."
"cheers , yeah measured mine 24mm" (why isn't the quote function working?) Yeh? Only 24 mm? My AU1 forte has 28 mm. Funny they decreased the size. |
03-07-2010, 02:43 AM | #7 | ||
Its possible the AU1 is hollow, whereas the AU2-3 is solid..
Just a thought. Not sure how they would compare though..
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
03-07-2010, 07:40 PM | #8 | ||
All rear AU swaybars are hollow. My standard swaybar mearsured 23mm, whereas the whiteline item is 22mm. However the weight difference is increadable.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!! |
05-07-2010, 11:48 PM | #9 | ||
series 1 xr bars were thicker but all series 2/3 are the same I was told by ferntreegully auto salvage.
series 1 and 2/3 are not interchangable as designed to fit different lower control arms series 1 are old school pin and bush design while series 2/3 are like a ball joint. hope that helps. |
