29-06-2010, 04:51 PM | #1 | ||
450rwk
Howdy,
Can anyone tell me if BA series1 XR8 front calipers,rotors and pads will direct fit onto AU seriers1 front or what I would have to do to get it to fit??? Cheers Scott |
29-06-2010, 05:58 PM | #2 | ||
you need the whole upright that the hub bolts to, as the caliper mounting holes are spaced further apart , ba caliper is alot larger , with smaller lighter pistons i put the ba ones on my au s/3 if you can get them cheap they are good little upgrade. i picked my ba hubs , uprights , calipers , front & rear for $56.00 of ebay , wreckers will charge you like a wounded bull , you wouldn't even get a single caliper for that price , cheers
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL Last edited by sleeper393; 29-06-2010 at 05:59 PM. Reason: missing info |
29-06-2010, 06:16 PM | #3 | ||
450rwk
cheers for that i got everything already except for uprights.
29-06-2010, 07:53 PM | #4 | ||
The only thing u'll see!!
On the six cylinders everything just changes over, Ive installed BA XR6 front brakes on my AU and it all just bolted up.
29-06-2010, 08:48 PM | #5 | |||
You can't stop the signal
On series 2/3 cars the callipers will be a direct change.
On series 1's though it is change the front suspension. That is sway bar + mounts, lower arms, uprights, and braking system (including lines). Here's a thread on what's needed and how to do it. http://www.fordforums.com.au/showthr...69#post2720169 Cheers
30-06-2010, 10:18 AM | #6 | ||
Blue Blood
So would BA XR6 or 8 brakes be a good upgrade on an AUII Fairmont Ghia?
30-06-2010, 12:14 PM | #7 | |||
They are an alright upgrade if you can get the parts at a good price.
This is because they are not much larger than au2/3 stuff. 298 Vs 287. But looking at the calipers, they look like they would be stiffer than the au2/3 calipers, but that is my own sumising. You'd be hard pressed to tell that from within the car though. The good upgrade if you can get them are either the BA premiums/GT brakes (black or blue PBR caliper), or BF XR6T/XR8 calipers. The premiums are 325*32, and the BF gear is 322*28 Cheers
30-06-2010, 01:06 PM | #8 | ||
Blue Blood
Cheers for the info. Sorrry about fastxr8
30-06-2010, 09:15 PM | #9 | |||
30-06-2010, 10:04 PM | #10 | |||
AU1 pads are 130 x 62 x 13 mm AU2/3 Pads are 169 x 62 x 16 mm BA pads are 190 x 58 x 15 mm (longer but not as wide as AU2) BF XR8 pads are 184 x 63 x 14 mm
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 30-06-2010 at 10:13 PM. |
30-06-2010, 10:31 PM | #11 | ||
i've put ba setup on my AU S/3 , only cause my originals were shot , as above i got the whole ba setup for $56, reco'ed them still worked out cheaper than fixing the AU ONES ,had the braking system tested on a brake retarding machine they definatly showed better braking improvement , for a small outlay.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
01-07-2010, 03:43 AM | #12 | |||
01-07-2010, 07:39 PM | #13 | |||
01-07-2010, 07:49 PM | #14 | ||
[/B]SPEED DOESN'T KILL ITS THE SUDDEN STOP AT THE END !
