Old 08-03-2010, 08:05 PM   #1
adrian302
Default Connecting amp, sub to stock deck
hi,
just wondering if i could have some help, i have a AU and it has the stock 6 stacker deck just wondering would i be able to connect a amp and sub or aux cable?
adrian302 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2010, 10:28 PM   #2
webby_191189
low wagooon
nide a line in convertor, can be bought from supercheap, autobarn, repco.
Plug speakers wires into the little box at one end and out the other end comes RCA's
As for the signal wire hook in itno an accesory activated power wire (something that turns on when you turn the key to accesorys)
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2010, 11:04 PM   #3
bodes-sh
some amps also have high level input, which is from normal speaker outputs from a head unit. i have a sony amp in my au that has this, you only need to run battery power and ground to it, the high level input acts as the accessory input to turn the amp on. because i have an lpg tank in my boot i just have the amp switched to low pass filter and have it hooked up to my 6x9's in the parcel shelf and use them like subs. not bad for a cheap setup
