Is it possible to tune an AU XR8 mafless with the factory ECU???
have a stroker motor going in and am not too keen on going to an aftermarket computer but will if i have to, if so has anyone got an aftermarket computer in their car that they recommend??? |
why do you need to go mafless?
it could be done using a map sensor that uses same signals as the factory maf, it should be something simple like 1-5v
What Wheelspin?
maybe an au 6cyl map sensor. they work off voltage,.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
#5 | |||
its to clean up the engine bay as ford must of had their eyes closed when designing it then just put an engine cover on there to hide the cr*p am looking at an lod school setup with a throttle plate atm and to redo the engine bay over time |
Stroking it...
Wow its a lot of money to have to spend to clean up the engine bay...
But yes, it will require a different ECU. Or as suggested possibly MAP would be the easier way..
Had: 347ci AU Then: ![]() Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
#7 | |||
Back on the road
I believe the MAF-less tuning on the early 5.0L Falcon EECs has been done using Alpha-N tuning (using TPS and RPM) rather than Speed Density (MAP sensor). I dont believe the MAF-less tuning has been succesful on anything post EL Falcon though...? Give Chiptorque a ring.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
its possible to do it in the E series coz they have an ECU capable of dealing with it (EB's had a map sensor as well as the MAF) but they changed to a dif ECU in the AU
how would you go about using the six cylinder MAP sensor on the V8??? |
#9 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Gary, AU1XLS's ute was a mafless tune set up, running through a Heltec ECU.Was a bit of a pain to get set up but made some good numbers in the run in stages but was pinched and blown up before it ever made its full potential, send him a PM and he can fill you in what it took to get it to run rite. Here's a bit of the original video we did messing around with it, was Tuff as
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
The Destroyer
I ran my auxr8 for 25000 very hard and faultless km mafless using a tuned stock ecu.
I have since gone back to a maf as I scored a free one.
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
#11 | |||
How did you go about this??? did you use something else like a MAP sensor or something dif??? |
#12 | ||
i dont understand whats the point of a mafless tune? is that because the maf is restrictive?
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
#13 | |||
Back on the road
#14 | ||
Hmm a lot of bother for that lol
#15 | |||
The Destroyer
I had a 80mm maf I purchased when re-built my motor but it died.
#16 | ||
Stroking it...
Well, I get to prove myself wrong..
My car is going in for a mafless tune with the stock ECU and an old chiptorque chip...being done at chiptorque.
