Old 05-01-2010, 09:28 AM   #1
Sox
RIP...
Sox's Avatar
Default Door lock issues
Attention all you AU door lock ex-spurts......
We have a AU2 poverty pack ute with intermittent door lock problems.
Doors will be locked only to open at any time between virtually straight away, to perhaps 2 days, by themselves.
We've replaced both door actuators and had a reasonable glance for any suspect wiring. It is possible the replaced actuators are also bunk because they were second hand.
An auto sparky guru we've spoke to suspects it's the BCM, of which I'm not convinced.
Any ideas?
Oval Everywhere...
Old 05-01-2010, 12:00 PM   #2
Beer Baron
Can you disconnect one of the actuators and lock both and see if it will unlock the connected actuator ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2010, 11:47 AM   #3
Sox
RIP...
Sox's Avatar
In the process of trying that now, will report back in a few days.
Any other ideas?
Oval Everywhere...
Old 11-06-2014, 07:37 PM   #4
Sox
RIP...
Sox's Avatar
Default Re: Door lock issues
Bit of a thread mine, but also closure.
This ended up being water leaking on the loom in the drivers footwell.
Spraying WD40 and unplugging/plugging the connector several times solved the problem.
Obviously fixing the water leak helped too...
Oval Everywhere...
