Old 25-12-2009, 07:15 AM   #1
rattus18
Default coolant confusion
Merry Ccristmas all, I was wondering if anyone can tell me EXACTLY what type of coolant I should use in my 2004 1.8L zetec focus. The fluid used to be red or orange but I had work done to it and it was replaced with std green stuff. Please help?
rattus18 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 08:26 PM   #2
pertuan
Focus on my Focus
I have an LS but yours should tell you in the manual along with all the specs for the other fluids in your LR.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 09:08 PM   #3
olfella
Cranky old bastard
Nothing wrong with going green - only make sure you replace it within the twelve month or two year life of it. Just ask the bloke who replaced it if it is the long life (two year) or not.
"But really...what can possibly go wrong"
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2009, 06:53 AM   #4
rattus18
Cheers, I wasn't game to drive it, but I think I will go back to original fluid
Old 27-12-2009, 10:22 PM   #5
FOCUSonTHIS
FOCUSonTHIS's Avatar
I would recommend using the Red coolent. Also put in distilled water as well. When I had my Focus I replaced with it with the orginal Ford coolent....expensive but worth it in my books
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 28-12-2009, 08:07 AM   #6
rattus18
Yeah sounds good. Cheers.
Old 01-01-2010, 08:16 PM   #7
NO2
Old Man
The red and green are 2 different types. the green is B type I think and is for older cars. Newer ones use the red. Ask at your local car parts as you don't need to use the ford brand.
NO2 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2010, 09:26 PM   #8
FOCUSonTHIS
The new Falcon still uses green. It is just a different type of coolent. I think the red caters for the european winters a lot more
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 02-01-2010, 12:10 AM   #9
melbzetec
Old enough to know better
melbzetec's Avatar
Just don't mix the two colours. Choose either one of the other, but not both
Old 05-01-2010, 04:51 PM   #10
rattus18
Sounds good to me. as long as I dont mix them I should be fine
Old 18-01-2010, 10:25 PM   #11
XR Martin
XR Martin's Avatar
Red is just organic coolant, (which probably makes it worse than the green.. ;) )
2004 BA wagon RTV project.
Old 18-01-2010, 10:51 PM   #12
mrbaxr6t
mrbaxr6t's Avatar
the red is arguably better stuff lower ch temps and does a better job at keeping your engine cooler - but the cost jump of red over green is too high to justify the couple of degrees in temp it saves you - it is better stuff in terms of temperatures but if your cooling system is performing so badly that you NEED the red over the green you need to fix your cooling system
the above comments are based on red being this below:
if by red you refer to "water wetter" url : http://www.redlineoil.com/Products.aspx?pcid=10
that stuff is red and is superior - but I googled and found that "red" is kindof a "longer life green" so to speak
I use standard green concentrate (usually nulon) with distilled water, or if in a pinch tap water
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 09:06 AM   #13
Mainlube
Mainlube's Avatar
The yank standard is what the world standard has copied.
The Australian Standard is a copy of the American, our spec is just a little tougher. (allowable loss of aluminium in the corrosion test is less for oz)
The spec you are after is AS2108.2004.
Colour doesn't matter.
Organic Acid coolants are the best (that's what we make) Organics have a much larger alkalinity reserve.
Don't mix different types of inhibitors.
Steve
MainLube - Extreme Lubricants For Overdriven Machinery
Mainlube 175 Synthetic Race Oil SAE 10w60 (engine)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff)
www.Mainlube.com.au
Mainlube is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2010, 10:01 AM   #14
Fredo
Nice kitty . .
Fredo's Avatar
Don't mix them . . cause red and green makes a nasty brown colour and anything brown only belongs in Camrys NOT Fords!!
Sorry . . . I could have said Red goes faster, but I resisted :
Just remember, amateurs built the Ark and professionals built the Titanic!
Late 2005 LS CL, 5spd Manual, 5 Door, Titanium Grey
To Do List:-
:- Using 95 RON Fuel (DONE -easiest upgrade of all) :- XR5 Springs (DONE) :- Lower air box removal (DONE) :- K & N Panel Air Filter (DONE)
:- 2.25" Cat Back (DONE) :- DBA Brake upgrade (DONE)
Fredo is offline   Reply With Quote Multi-Quote with this Post
