Old 31-05-2005, 12:28 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default AU BCM - What does it control?
Guys, just want to know what the BCM controls?
AFAIK, it's power windows and cruise control. What else does it control?
Carless
Old 31-05-2005, 01:35 PM   #2
au-steve
fully *** turboooo
au-steve's Avatar
everything but the engine and trans?
AU1 Forte
178.6rwkw @ 5 psi
Highflowed T03, Intercooled
Full comp insurance :nutsycuck
au-steve is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2005, 08:29 PM   #3
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
The BEM controls:
LOW SERIES MODELS
• Manual control of illuminated entry and exit delay
• Manual boot release with security time out and speed dependant disable
• Remote central locking with hazard acknowledgment
• Manual central locking
• Remote drivers door lock /unlock
• Panic alarm
• Key in lock warning horn/hazard
• Anti-Theft warning LED
• Remote control for illuminated entry
• Remote boot/ tailgate release with hazard acknowledgment
• Door unlocked horn/hazard warning
• Automatic door relock timer
• Transponder challenge/response immobilisation
• Heated backlight timer
• Front intermittent wiper timer with fixed dwell, wipe on take off
• Front wipe after wash timer with fixed number of wipes
• Diagnostic capability of inputs, outputs and trouble codes
• Diagnostic self test
• Battery saver for dome, boot and glovebox lamps
• Power window supply control with key off
HIGH SERIES MODELS
The additional functions to the low series are as follows:
• Front intermittent wiper dwell timer with variable dwell and speed dependency
• Front washer motor control
• Instrument cluster illumination (LCD & Graphics) control
• Power antenna control
• Automatic headlamp switch off action with manual override
• Headlamp warning chime, headlamps on, ignition off.
Mid series vehicles use a high series BEM with a number of the functions disabled.
Examples are headlamp delay, single dome lamp circuit, no front washer control.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2005, 11:17 AM   #4
TheSneakiness
Adapt or perish...
Originally Posted by russellw
The BEM controls:
LOW SERIES MODELS
• Panic alarm
Thanks Russ, now, I'd assume that my ute would have some/most of those functions, therefore I assume I'd have a BEM module in the ute.
Sounds stupid, but I'm actually learning something new here.
Carless
