Old 05-12-2009, 11:02 AM   #1
20focus05
I wanna XR5
20focus05's Avatar
Default One Stuffed Clutch
no wonder i had a vibration!!!
lucky this was on the pressure plate side, so flywheel all good
I got an exploded diagram from ford of the clutch area before i pulled it appart. Shows a one piece flywheel but once apart its a dual mass! very glad it was ok cause it would have ment a new one if it was damaged.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2009, 12:49 PM   #2
BlackLS
yum
Wow thats insane
2005 LS Focus LX
250,000kms.
Old 05-12-2009, 01:24 PM   #3
rand0mn00b
too many burnouts!
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2009, 03:18 PM   #4
819_FLY
819_FLY's Avatar
Was the flywheel side still intact??? Must be a result of dropping the clutch pedal, the shock would have broken apart the organic facing where the pressure plate met each time, and eventually the facing just gave out...
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 08:49 AM   #5
Dustproof
Dustproof's Avatar
Still should not have broken, the linings should be glued AND riveted. This looks to me to be a faulty part because these things are designed to wear down, after years of building race cars I have never had one do this from dropping the clutch even with 600HP.
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 10:39 PM   #6
20focus05
I wanna XR5
20focus05's Avatar
About 10 months ago I tried! to take off from a set of lights and was in third!!! not first like you should. I did a good job cause after pulling it out of gear while still rolling along the clutch pedal just went to the floor (stuck it together).
I put a bit of force on the gear stick and it finally went into gear (while still rolling along) and clutch pedal came back.
It then shuddered when initially taking off but after that all other gear changes ok.
so thought I had just glazed the clutch.
a few months later i flushed the clutch fluid, It was black!
But no real vibration till about a week ago and getting hard to change gears.
Took me about 4 hours and $650 to do the clutch, did the axel seals also.
Later that day the wife took the car, took off from a set of lights and as the clutch is lighter now dropped it and lit the tyres up. So yeah too many burn outs!!!! lol
