Old 18-11-2009, 01:40 PM   #1
Pazuzu
Default Rear wheel bearing change
Hi All.
Had a crack at removing the rear stub axles from my Mk. 2 Escort on the weekend. Managed to remove all the bolts I needed to, but found it friggin' impossible to pull out the axle. Didn't want to start hitting it with anything harder than a copper hammer, the manual suggested some form of slide- hammer be attached to the 4 protruding bolts.
I had a look around for a tool to do the job, but all of the usual retailers were useless (I'm looking at YOU, SuperCheap) or told me it would take a few weeks to order something in.
Anyone have any time- and budget- friendly suggestions for dislodging the rear stub axles?
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2009, 05:42 PM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
I used to use an old wheel spacer with a bar welded across it - then gently give it a tap with a hammer if it wouldnt come out by pulling, usually once you have cracked them they will come out
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2009, 07:29 PM   #3
2lt_Scort
I use the old brutal method of flipping an old rear brake drum over, bolt it on backwards and beat the crap out of it.
Mk2 2dr 2lt Escort
Mk2 2dr 1.6lt Escort - now a 2lt.
2lt_Scort is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2009, 08:33 PM   #4
V8falcons
V8falcons's Avatar
yep,or a wheel loosely bolted up,and use it as a slid hammer.
she will come out
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2009, 01:54 AM   #5
oysta
Escort MkII 1977 2.0L
Rubber mallet worked for me. I have bought a sliding hammer from supercheap for about $15 a few week ago but haven't tried it yet.
Try the reversed drum method with a mallet to prevent damage or the loose wheel should work well too. I had more trouble sliding the new bearing in since the oring slightly protrudes...had to beat the crap outta it.
oysta is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2009, 06:50 PM   #6
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
there is a step by step help guide on just this problem
HERE
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2009, 12:13 PM   #7
Pazuzu
Thanks a tonne for the advice, people.
Old 22-09-2011, 05:09 PM   #8
tappets
Default Re: Rear wheel bearing change
A slide hammer or jack it out with two bolts, the threaded part protruding through the stud holes ( remove the studs first) the head pushing against the axle. Forget flogging it with a hammer, it damages the hammer!
tappets is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 09:40 PM   #9
allanv6gt
Tippy-tronic Free Zone
Two bolts thru the holes in the flange for the axle keeper plate, with big washers between flange and casing to push against. Works but fiddly.
OR...
Slide hammer from a handyman dent puller kit. (picked mine up at a swap meet at Cootamundra years ago). Just need a piece of angle iron with drilled holes to fit over the wheel studs, with the slide hammer thru a centred hole to pull against. Works a treat.
Old 07-02-2012, 01:01 PM   #10
broms
Thank you very much for the info
broms is offline   Reply With Quote Multi-Quote with this Post
