Both the central locking and traction control button LIGHTS are dead. Do I have to remove the entire centre console to replace whatever is illuminating them?
Tried for a simple search on the forums, can't seem to find any specific answers. |
#2 | |||
You can't stop the signal
You should be able to unclip the surround that is around those two buttons + the demister button.
Once that is out you should be able to unclip the buttons from the center fascia, and the lights then simply screw out. Don't ask me where the clips are on the surround though. I don't own a Fairmont. Cheers
![]() Join Date: Nov 2007
slide a card (credit card etc) in the top- and bottom of the oval fascia around the 3 or 4 buttons. it will come out seperate to the whole fascia. Then unscrew the bulbs as described above.
Prise the switch fascia off starting at one end and working along - it has two small tangs at each top and bottom edges and also one at each of the ends.
Once it is removed you will see there are five "holes" for switches to be fitted - not all will be occupied. Put your finger into a vacant hole and push the adjacent switch outwards (towards you) with wiring plug still attached. Once the switch is out you can unplug it to make it easier to remove the globe. You need a fine precision screwdriver to remove the globe - the globes are about $6 each from your local Fraud dealer. |
The Monty
special note... make sure they are the FORD part as repco, supercheap and others are a Yellow/orange glow to them and looks crap and really noticable and are around the same price n e way
brad` |
All Bran = Regular Member
You can also take the opportunity to swap them for blue/red/whatever leds
Which LEDs do you get? Got a part number please?
#8 | |||
It's an easy DIY job. If you want a few to try it out pm me an address and I'll send you a few. |
Thanks people, I'll have a go during the week when I have some time off Uni.
I'll be sure to report back. |
Better refer to post #4 ... save me having to type it all again!
ronwest> thanks for the link - I will suss it out and if I have no luck I may take up your kind offer. |
#12 | ||
Whilst sorting out headlight pics I came across a pic of the blue leds, so I'll stick it up for posterity...
Ever considered completing the whole blue look by changing the lights to the shifter too?
Looks pretty sexy. |
#14 | |||
Easy to do but just haven't got around to it. |
#15 | ||||
Captain Malcolm Reynolds
How do you go with visibility of your needles on your dash like that?
I still have to have a couple of normal globes in there so I can still see my bloody needles
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
#16 | |||
I played around with white paint, then luminous paint but there's not enough extraneous light for either to work efficiently. At the centre of the guages (speedo/tacho) the needle is easy to see so it's not a desperate problem but I've yet to chase up VDO about different needles to suit. Hopefully they'll have something that will work. |
#17 | |||
It looks to me like you can unscrew the sat nav screen pretty easily to gain access - if you can't easily remove the sat nav screen in order to push the switches from the back then you will have to use a fine screwdriver to prise the switches out from the front. They have tangs on both sides. |
#18 | ||
Cheers T3man.
Do the globes have a particular reference number? Or do I simply go to a local ford dealer and say "hey I want to replace the globes in my dash". |
#19 | ||
Ford Part # ... ER 10B765 D
Cost about $6.40 each - they come with blue condom already attached. |
#20 | ||
That sounds a little expensive for a single globe. T3 do you happen to know if they do other colours besides blue. Has anyone tried replacing their dash face with onne that has the white parts (the numbers on a dial) in a different colour. This would allow you to use a white globe which should help needle visability.
Weekend AUII xr8 Daily 1988 F250 460 Hers Eb xr8 |
#21 | ||
'corse it's expensive - you can only get them as genuine Ford items - no one else makes them. Yes, you can also get green - the part number is the same except it has a B on the end.
#22 | |||||
They're like one or two bucks each, but then you'd have to buy the coloured condoms as well but they still shouldn't equal $6.40 per globe! And thanks ronwest for the info on the needles. Someone else showed me a pretty cool way to get needles glowing in an R31 Skyline, had the same issue where if you replace the backing dashlights with blue, the needles wouldn't show. He stuck a tiny surface mount red LED on his actual dash sort of under the bit where the needle attaches, needle now glows beautifully. Seems like a bit too much effort for me to go to though. If you do find VDO have anything would be good to know.
#23 | |||
The globes are a direct swap into the existing globe holders. I think that other colours are available. Last edited by ronwest; 13-08-2009 at 01:31 PM. |
#24 | |||
I read that the AU1 needles are "painted" red and the red can be scraped off. AU2/3 needles are definitely coloured plastic so scraping won't work. If anyone has an old buggered Series 1 cluster they may be able to remove the needles and scrape 'em so we know ![]() |
#25 | |||
#26 | |||
#27 | ||
Thanks for all the good info guys. I think i may just have to go do this to my car.
#28 | |||
The switch globes are removable from the holder. Its a matter of unwinding the "leg" on each side (+ and -). To install led's you solder a resister onto the + and wind the legs on Here's a pic of the smaller led showing it "unwound" ![]() |
#29 | ||
In a Ford..at last!
I'm guessing this happens in the Au's with age? Cos I've got the exact same problem but cbf doing something about it ;)
#30 | ||
Lost Boost Gained Class
ronwest if you find out where to get needles or a way to make them better to see Let me know please i have done what riksta has done so i can see the dam things and would like to make them better i think u can get new one someone on AFF has done it with his EF -EL i cant remember who though
2006 BF Fairmont Ghia
2001 AU Falcon |
