Old 12-08-2007, 10:57 AM   #1
glonius
Default KH laser - fan not kicking in
I'm having issues with my 93 kh laser where the engine overheats, and i think it's because the fan is not kicking in. any suggestions on what to do?
glonius is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2007, 10:57 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
get two wires running from the battery and direct test the fan
replace the resistor /check all the wirin connections
fit a new thermostatic operation switch
go to a wrecker and buy one that works
My car goes Brumm Brumm
Old 13-08-2007, 12:03 AM   #3
smally289
growing up is optional
smally289's Avatar
Easiest way to check the fan is to unplug the thermo switch near the distributor. It will have a single wire going to it. The fan should run with the wire disconnected and the ignition on.
If it doesnt, you will have to look further for a wiring or fan motor fault.
If it does, the wiring is fine and the thermo switch is stuffed.
smally289 is offline   Reply With Quote Multi-Quote with this Post
