29-07-2009, 03:08 PM | #1 | ||
now its been dyno proven that my car would make much better top end with a better intake but at the moment i cant afford anything...
whilst my dad was at the wreckers picking up a fuel cap (i lost mine :togo: ) he picked up top top half of a BA airbox and all the intake piping the piping is quite obviously larger and less restrictive than the au piping, also shorter as well as there is one big curve compared to the sharp bends of the au iping the airbox opening is also 75mm i believe, or maybe it measured to be 80 i cant remember, either way roughly 3" its probably not gonna give me a huge gain but for now its free and its something to work on so im going to fit it anyway and if i stuff up i have a spare au airbox anyway! the boxes mount up different so i am going to have to fix that up somehow, i might need to do a bit of chopping and get dad to do a bit of welding has anyone else done this mod? i did a search and came across a thread but the pictures had long since expired and id love to see what others have done to make my job a bit easier thanks guys
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
29-07-2009, 07:59 PM | #2 | ||
BA box into an AU will not give you any real gains at all - you'll gain top end but sacrifice bottom end.
29-07-2009, 11:52 PM | #3 | ||
whys that for, cheers
30-07-2009, 01:19 AM | #4 | |||
im not overly concerned about bottom end at the moment, im trying to open it up and gain top end, i dont know if you know but ive got a big cam in now and i plan to get better diff gears and a 3000rpm stall converter so im looking to make my power upwards of there
30-07-2009, 09:18 AM | #5 | ||
do as many have done before and go the BA pod style airbox.
30-07-2009, 01:39 PM | #6 | |||
30-07-2009, 01:40 PM | #7 | |||
30-07-2009, 02:01 PM | #8 | |||
Resident AFF detailer
30-07-2009, 07:03 PM | #9 | |||
would a fully exposed pod pull in much more hot air than a pod in an airbox? i dont know why my dad didnt grab the lower half of the airbox it looks like its gonna be quite difficult as the corners of the ba top half are rounded and the au box is square also a pod style airbox, they are the aftermarket ones right? like the bluepower (i think.. maybe it was g & d) airbox? if thats the case... not really what im looking for, as i said im on the cheap side at the moment
30-07-2009, 07:12 PM | #10 | ||
No they are an enclosed Pod filter box. came on the BA GT/XR8. they have 2 openings , 1 behind the headlight and 1 for the factory snorkel. I got mine for $150 from the wreckers.
http://www.fordforums.com.au/showthr...9&page=5&pp=25 Check out my build thread. Post#122.
30-07-2009, 07:22 PM | #11 | ||
The Monty
you were thinking about G&D's airboxes around $200ish mark might be wrong tho, not leaving the pod in the box and having it free gains alot more heat from the engine the plastic airbox reduces the heat going into the filter, hence why the only openings are one from the upper/lower intakes.
in saying that you can make a make shift one, using metal? i think as a heat shield someone did one not sure who but read it on a post a while back cheers brad` |
30-07-2009, 08:03 PM | #12 | |||
30-07-2009, 08:46 PM | #13 | ||
The Monty
i know, but it might not be metal then haha its something along those lines...
30-07-2009, 10:02 PM | #14 | ||
I was planning on building an aluminium airbox of sorts that would fill the area from the wheel arch to the headlights and back again, my thinking being the aluminium is good at dissipating heat. Really only a cloud of ideas at the moment, but I reckon it'd work.
30-07-2009, 10:36 PM | #15 | ||
hmmm mont 5.0 i see what youve done, looks really tidy and is probably deals with the heat pretty well
$150 from a wreckers lol... even if i can find a wrecked gt or xr8 (like the parts would last long anyway)... i could still buy a brand new aftermarket box for a bit more than that as for the people discussing metal, yeh aluminium is the lightest and would probably deal with the heat alright but not much better, thing is they can be heat proof coated anyway i tried out a mates pod filter the other day, didnt feel a positive difference, left it in the airbox but i used some of his piping which has a slighly bigger exit from the airbox car also sounded pretty week... didnt think it would make that much of a difference thats not where the real restriction is anyway and as i said the piping was only slightly better (it was part of the jim mock intake kit btw)
31-07-2009, 09:59 AM | #16 | ||
Lost Boost Gained Class
yeah maybee u need to go look at G and D's Air box setup like i was saying the other day thats what ill do after i get some work done my my au ill chage the Jim mock one for something like the G and D one
2006 BF Fairmont Ghia
2001 AU Falcon |
