my au has developed a misfire ,i have changed spark plugs no difference .It seems to happen under load ,it idles like normal it misfires as soon as throttle is opened . im trying to figure out wheter its an eletrical or fuel problem are there any fuel filters in the fuel line ?
try leads and coils first. there is a fuel filter. it's in the line just in front of the petrol tank, almost in line with the left rear wheel
Made the 300 :0)
As said leads,might be a dirty MAF wire are you running a standard intake.
Fuel filter if you have done alot of K's. At night or a dark carport have the bonnet up run and rev the car see if you can see spark jumping to the heads.
New Owner of a fiesta ST |
it was the heat shield on the lead sparking onto the head .
#5 | |||
Made the 300 :0)
