Old 19-06-2009, 01:09 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Sun visor, can't live with it, can't live without it.
I know I can't be the only one that has problems with the sun visor being too low when it's folded down. It would seem to me that anyone over about 175cm or 5'7" in old money is going to struggle to sit comfortably and still see under the visor in any AU. I have the issue in both the missus' wagon and my Fairlane as the seat won't go low enough.
I'm just wondering what, if anything, has anyone done to remedy this problem cos I need to do something to raise the lower edge of the visor about an inch at least I recon once it's deployed.
Bushbasher
MINE- AUII Forte
Old 19-06-2009, 01:59 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
try 5'9" for 175cm
ps 5'11" here, and yes the sun visor is just that bit too low. a side effect of a sloping roof.
what they used to do with the taxis to sometimes fit the meter between the sunvisors was to open up the sunvisor, chop off some of the guts and leave an overlap of the vinyl and seal it up. Not as nice looking as factory but didn't look super dodgy either. maybe cut some out of the bottom of your sun visor? or take your good fairlane sunvisor off and get a crappy s1 forte sunvisor from the wreckers and butcher it?
Old 19-06-2009, 02:55 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
Can't you bend the sunvisor forward towards the windscreen? This allows it to not have such a "letterboxing" effect. I'm 5'11" and don't have a problem with it.
Old 19-06-2009, 03:04 PM   #4
Bushbasher
Bushbasher's Avatar
Ok, ya got me Mr Hardware but I was only guessing, lol. Make that 170cm then, I'm 5'8" and the visor annoys the crap out of me but I'd rather not butcher the visor and I'd like to keep the originals in place (in both cars) if possable.
Bushbasher
MINE- AUII Forte
Old 19-06-2009, 03:11 PM   #5
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Im about 175cm and its far too irritating trying to fold the visor all the way down against the windscreen. When i absoloutely have to, ill fold the visor down slightly (so its pointing at my face) and block out the sun. It was a little disconcerting at the start having poiting at me but ive gotten used to it.
The designers shouldve made sure it sat flat against the windscreen, my biggest gripe with the AU!
LeadFoot81 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 03:15 PM   #6
ronwest
All Bran = Regular Member
Originally Posted by LeadFoot81
ill fold the visor down slightly (so its pointing at my face) and block out sone of the sun.
That's what I've always done with cars, although I just drop it as low as it needs to go to bock the sun (and still be able to see the road).
I'm 5'10" so in the same general range as most.
Never found it to be a problem...
edit: until now... lol
Old 19-06-2009, 03:18 PM   #7
Bushbasher
Bushbasher's Avatar
I tried that but there's 2 things working against that being effective -
1) once it's swung forward there's a point where you can feel the resistance ease off (to rotating the visor), like there's a groove at that point or a spring loaded "set" point where if you push past that the visor just comes back to.
2)the retaining seat in the centre of the roof is bulbous and because of the shape of the visor where the visor clips in, it presses up against the retainer and won't let the visor swing any further forward.
I must say Dauphin, if you can see under the visor comfortably you'd have to have the seat layed back a fair way to get your line of sight that low. Either that or you're built like a Gibbon, all arms and legs and a short body, lol. _2:
Bushbasher
MINE- AUII Forte
Old 19-06-2009, 03:32 PM   #8
Mr Hardware
yeah i'm sort of an anti-gibbon, short legs and arms but large torso (amongst other things) so i sit rather forward and upright for a bloke. and there's no way i'd have the visor slightly down facing me, i'd wanna punch it away in .01seconds
Old 19-06-2009, 03:48 PM   #9
Bushbasher
Bushbasher's Avatar
Originally Posted by Mr Hardware
... and there's no way i'd have the visor slightly down facing me, i'd wanna punch it away in .01seconds
Me too, having it that close to my head bugs me plus I don't like the idea of head butting it one day because you've come to a sudden stop.
Bushbasher
MINE- AUII Forte
Old 19-06-2009, 03:48 PM   #10
Whoosha
AU DIE HARD
Whoosha's Avatar
AU .COM hat (facing the rite way) and sunnys does it for me :
Originally Posted by Riksta
Old 19-06-2009, 04:55 PM   #11
Bushbasher
Bushbasher's Avatar
Ok, I think I've found a solution, may not be perfect yet but I think it's going in the right direction, here's what I've just done:-
First I loosened off the two mounting screws holding the visor in place. The rear one till it was out completely, then I put in some packers, in this case through trial and error, I settled on 10x 5c pieces under the rear screw and tightened up the mount. This has effectively rotated the whole thing forward about 10deg. Next problem is the centre mount fouling the visor and not letting it rotate further forward so I removed the mount and used my bench grinder to file down the front side of the mount to allow the visor to rotate fully. Now it rotates further round and has made the bottom edge on the visor just over the 1" higher I needed for a comfortable line of sight. The only drawback now, if you could call it that, is that the visor doesn't retract all the way hard up into the recess in the roof lining, it hangs down about 1/2" or 12mm but I don't find that an issue. With the visor up you can't tell the coins are there but down it does look a bit untidy (if you look,lol) so later I might look for something a bit more aesthetic if it annoys me enough.
So problem solved, : , and it's something that anyone can do with a screwdriver and file in less than 10 minutes. It's amazing what you can come up with when you have to, haha.
Bushbasher
Bushbasher
MINE- AUII Forte
Old 19-06-2009, 06:57 PM   #12
Mr Hardware
plus now your car is worth more
Old 19-06-2009, 07:08 PM   #13
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I have noticed this problem as well with my AU, although I am 6ft1, but it doesn't really annoy me that much as I don't find I need to use the sunvissor that often, as I sit high and the roofline act's as the sunvissor anyway.
Old 19-06-2009, 07:28 PM   #14
Bushbasher
Bushbasher's Avatar
not really, the change only moved from the drink holder in the console to the roof, lol. I don't think the insurance co. will be adjusting the agreed value any time soon.
MINE- AUII Forte
Old 19-06-2009, 10:10 PM   #15
Jimmyd
Same here - only I'm 6'5" an the roof line makes it a PITA to see traffic lights change.....
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 10:14 PM   #16
Ghiagirl
Budding Revhead
Ghiagirl's Avatar
Ahhh men! Try being 5'2 and copping sun glare galore because you're too short for the visors to do anything!! Now that's frusturation LOL. It sure makes me easy to spot in the late afternoons, just look for a chick who looks like she's waving to everyone who passes :
: Mine: Galaxy Blue (now Silhouette black) 99 AU series 1 Fairmont Ghia 5.0 litre V8, tickford sports package, 2 1/2" exhaust 17" RJR rims[/SIZE]
His: Winter White 99 AU Fairmont,6 cyl, 17" Tickford Rims, nice and stock
This mum's in mod mode
www.aufalcon.com/ghiagirl
Ghiagirl is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2009, 10:29 PM   #17
JC
JC's Avatar
O/T, but that comment reminds me of my mate and his hyundai excel - every time he fills it up, he triples it's value.
Back on topic - love the "bush mechanic" solution to this problem!
Ford Performance Club ACT
Old 19-06-2009, 10:48 PM   #18
Mr Hardware
yeah i think i do that too with my commodore
Old 20-06-2009, 07:38 AM   #19
Bushbasher
Bushbasher's Avatar
Yup, know that one, my missus is 4'10".
Bushbasher
MINE- AUII Forte
Old 20-06-2009, 09:56 AM   #20
Mr Hardware
wow thats mega short.
as usual, pics please
(of the sunvisor)
Old 20-06-2009, 01:19 PM   #21
Bushbasher
Bushbasher's Avatar
Ok Mr Hardware, but if I'm going to take pics I may as well do a better job than the first time. So to that end I went to work on the missus' wagon this morning and did a "how to" HERE.
Bushbasher
MINE- AUII Forte
Old 20-06-2009, 02:25 PM   #22
galaxy xr8
Giddy up.
galaxy xr8's Avatar
You could allways use a cushion or phone book,
Old 20-06-2009, 03:09 PM   #23
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
Yeah i'm nearly 6'7" and when ur at the pedestrian crossing u can't see the lights without leaning forward.
if i do need the visor i have it pointing at me. if i have it all the way down i can see a few meters infront of my ute
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2009, 07:58 PM   #24
ebxr82nv
Trouble with this method is if the unfortunate happens and the airbag goes off the front of the hat can have a scalping effect and that's something you don't want.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2009, 06:47 PM   #25
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
6' 4" here,..... I know your pain :(
First time I jumped into Mr Hardwares AU I was too 'small' to see over the dash and get a proper view of the road (not calling you old or anything mate =P) and now in my AU years later I can't see the effing traffic lights!
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2009, 10:51 PM   #26
Mr Hardware
oi oi oi
'nuff of that pipsqueak
Old 21-06-2009, 10:56 PM   #27
XRtowcar
Mustang GT mmmmmm......
XRtowcar's Avatar
Try to get hold of the retainers out of a BF as they recessed the post to allow the sunvisor to fold up just a bit further then AU/BA's.
Otherwise i took mine off and ground a bit of clearence into the plastic to achieve the same thing.
I have become a Mustanger.
XRtowcar is online now   Reply With Quote Multi-Quote with this Post
