17-06-2009, 08:42 PM | #1 | ||
I am looking at upgrading the suspension and getting koni yellow adustable shocks, full nolathane bushes kit, whiteline swaybars and reusing the king springs that are in there now.
The rear swaybar is an easy choice as there is only one size and type to choose from: 20mm heavy duty and i will be choosing the blade adjustable for when i goto track events. The front has got me stumped though as im not sure what size and type to go for as there is a few to choose from. I have heard that adding aftermarket bushes also have a bit to do with determining the right swaybar. Here are the available front swaybars that are adjustable: Swaybar 27mm-h/duty Blade adjustable Swaybar 30mm-h/duty Blade adjustable Swaybar 30mm-X h/duty Blade adjustable Which would give the best handling performance? I would rather sacrifice road comfort for performance as i plan on doing circle work when the car goes back on the road and want to have a competitive car when it does some competitive work. Car is an AU2 Falcon XR8. Thanks
Current: Built R32 GTR 520Hp ATW AU3 Fairmont I6 Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo Past: 2001 AU2 XR8 220 Manual 1/4 Mile: 13.8 @ 100MPH (161km/h) Ford Falcon AU2 V8 Auto 1/4 Mile: 13.0 @ 107MPH (172km/h) |
17-06-2009, 08:52 PM | #2 | ||
get coilovers :P
i won. |
17-06-2009, 10:54 PM | #3 | ||
Flairs - Truckers Delight
falcons already have a coil over spring type rear suspension.
17-06-2009, 11:35 PM | #4 | |||
17-06-2009, 11:43 PM | #5 | ||
Critical Thinker
The question is, what do you want your car to do?
1. Improved handling for street and occasional fun in the hills? 2. Better handling for heavy street driving and lots of hill work? 3. Hard handling on the street/hills with some track work? 4. Minimal street and heavy track work? 5. Pure track work? Depending on what option you go for I'd choose the following: 1. = 27mm non adj (front) 2. = 27mm adj or 30mm adj (front) 20mm (rear) 3. = 30mm adj (front) 22mm (rear) 4. = 30mm adj or 30mm Xh/d adj (front) 22mm+ (rear) 5. = 30 Xh/d adj (front) 22mm+ (rear) I hope this is understandable :P
18-06-2009, 04:02 AM | #6 | |||
Cheers for the help!
18-06-2009, 11:52 AM | #7 | |||
Critical Thinker
No worries mate, IMO having a sway bar thats too big for your application can ruin your driving experience as you will find oversteer can be prominent. But it also depends on your spring/shock combo too. I believe your spring/shock combo is of more importance than the sway bars. Having an adj sway is good if your into experimenting with your car on a regular basis. Do you do track work? How often do you like to play with your suspension settings? Are you looking to improving your times on a stretch of road or track? From what I have, I didnt want to set my car up purely for a track as its a daily driver, and I wanted some relative comfort as well as improved handling. I went the 27mm non adj on the front, and 20mm non adj rear. For me, this gave a good balance of handling without inducing oversteer. I have nothing against those who go the bigger 30mm HD adj versions. But to me there is no point going that big unless your intending to play with the settings to serve a designed purpose often. I know that you can get 22mm rear sways, probably not in the whiteline catalogue but possibly in the KMAC or Pedders range you could. Just be honest with yourself when you choose. Forget the 'fully sick' reasons and do it right the first time.
18-06-2009, 11:56 AM | #8 | ||
Resident AFF detailer
great advice Shav!
18-06-2009, 02:47 PM | #9 | ||
First time Falconless
I've got a 27mm adjustable whiteline front with a whiteline 24mm rear on my crate (non IRS rear), which I have found to be a good combination that gives the car heaps of grip and a relatively neutral handling feel. I agree with Shav that the spring shock combo will have a more significant affect on the behaviour of the car than the swaybars - which are a bit of a ham fisted method for controlling roll.
As far as sizing goes, don't go too big otherwise you'll have noticable understeer. I would say that unless you are planning on serious track work then a 27mm adjustable will be more than adequate.
2008 FG G6E Previous:- 2012 Fiesta Metal | 2001 AU2 XR6 | 1994 EF Fairmont | 2010 FG XR50 Ute | 2006 BF Typhoon | 2002 AU3 SR |
19-06-2009, 12:22 AM | #10 | |||
I will be getting into track work and want to play around with the adjustments on the shocks and swaybars to acheive the best setup for the track and be able to readjust for optimum settings for the street. I will be going with Koni Yellow adjustable shocks all round with king ultra low rear and super low front springs. I do want it to be fast on the circle stuff, quarter mile isnt a top proiority for my car. The car wont be driven daily but will be driven on the weekends. I dont mind a little bit of a rough ride but do want to be fairly comfortable when i drive it on the street. I thought that i could adjust the swaybars and shocks for a soft setting for the street and when i goto the track then adjust it back to a stiffer setting?
19-06-2009, 11:41 AM | #11 | |||
Critical Thinker
Sounds like your going for option 4. Good choice for shocks. Koni's are excellent. Although Im not a major fan of King Springs, you should get excellent handling characteristics on the track with that combination of shocks/springs and sways. Are you doing a urethane bush kit too while you at it? Have you looked into strut braces, and performance trailing arms (assuming you have live axle rear)? Let us know how you go on the track.
23-06-2009, 01:42 AM | #12 | |||
Car has independent rear suspension which is an added bonus for track work. Will let you know how i go. CHeers
23-06-2009, 02:31 PM | #13 | |||
Critical Thinker
17-07-2009, 09:22 PM | #14 | ||
ive just bought 26mm swaybar mount bushes for my au, will they fit with a 27mm bar?
19-07-2009, 09:55 PM | #15 | ||
Critical Thinker
They'll be a little tight. Be sure to add heaps of grease if you decide to fit them.
22-07-2009, 09:54 PM | #16 | ||
Just spoke to a couple of suspension shops today and it seems that they reccomend either a 27h/d adjustable front with 20mm h/d adjustable rears for street and occasional track or a 30mm h/d adjustable front and 20mm h/d adjustable rear if I'm going to be doing track work with minimal street.
I was close to putting the order in for the 30/20 combo but thought I would post here to get some thoughts. Car will only be used on weekends and track days. Any ideas if I should go ahead and get the 30/20 bars?
23-07-2009, 12:46 AM | #17 | |||
Critical Thinker
