Hi everyone
I saw in a another thread, someone had a B series ss inductions big mouth snorkel fitted to their TE50, I've been looking around cos i wanna do this, but i can't seem to figure out which SS big mouth fits.... It seems that there are many different sizes, even varying between BA and BF and XR6 to XR6T of the big mouth snorkel... Anyway i wanna try and fit one on my au xr8, but don't know which will fit? Ill try and find the thread to show u guys..... But in the meantime has anyone done this? Also i have the BA pod setup, thats why im doing it.... Thanks |
Ring ss indusctions, or rocket industries. And find out- they might do one for the au's? If not any of them "should" fit with a bit of dremel work ;)
or find the thread and ask, whom ever has it done on the T3? |
low wagooon
try ssinductions website, listed on there the part number you need
Webby
S2 AU XR6 UTE |
Barra Turbo > V8
IIRC SS dont make an OTRCAI for AU's the one fitted to the TE would have been a BA OTR modded to fit AU
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
Teh Baest
1999 Liquid Silver AU Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!) Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler Coming..CMS Stg2A Cam, 68mm TB Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220 Currently: 151kW (165 on other dynos ![]() |
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
There is an SS Induction For Sale in the AFF For Sale Section - its from an AU
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
not here much anymore
The above one in the link is the right one for an AU V8, and you can use the standard airbox or modify a BA Pod one to suit.
RAM 1500
low wagooon
http://www.ssinductions.com.au/auxr6xr8.htm
The ones in this link have this alluminium air scoop as well. I cna vouch for the fact that you can fit your fist in the entry of the ss inductions kit to and the hole where it goes to the airbox is a lot larger to
Webby
S2 AU XR6 UTE |
#9 | |||
Barra Turbo > V8
#11 | |||
low wagooon
Webby
S2 AU XR6 UTE |
#12 | ||
It's a Ba turbo one.... But id think you'd get much much better flow from say a factory fg xr8 one hey! ;) You'll notice with anyone who fit's an ss inductions ba turbo one it's only a matter of time before it sag's and honestly there just not that large and definatly dont justify $350+ Although my mate with a ba turbo reckons it was a good mod.http://i319.photobucket.com/albums/m.../Stripdown.jpg
As you can see he's has been on 6-12mths and is now sagging pretty bad though. Look for austin bf2s thread when he was selling his new fg system... you can see what i mean by big. It's what you want i reckon! But if your set on the ss induction one, make a large prop of sorts in the middle to try stop it from closing up ;) Last edited by dreadly; 08-06-2009 at 04:09 PM. |
But would the FG system fit? I'm actually considering trying to fit it.....
#14 | ||
I dont understand by what you mean by would it fit?
None of em are going to fit without some sort of modifying hey. Choose which one you want, buy it, then go about fitting it..... They all close under your bonnet, some might require an extension, or a larger hole cut into your pod box etc. common unless you buy one, completely designed for what you have, they'll require some work.... ya did know thats there's fordmods.com with a wa section? lol * Note i wanted when they first came out an F6 snorkel on my au box, so i brought one and went about fitting it! http://cgi.ebay.com.au/ws/eBayISAPI....m=260422725453 where there's a will there's a way! Last edited by dreadly; 09-06-2009 at 12:47 AM. |
