Hey guys, im doing a cam upgrade on my au xr8 ute.
And wanna know if i need to replace the lifters? Rang crow and they said they'd only be replacement ones as there already in there? And can it be done without removing the front bar and having to de/re gas the a.c? just the radiator and fans? |
Sales Representative
If you are upgrading, you may need 1.72:1 Roller Rockers... Yella Terra do these also.
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
You should always install new lifters with a new cam. Make sure you use some cam lube on the cam and put a dab on the bottom of the lifters before you drop them in.
I don't understand what are talking about regarding Crow and replacement ones are already in there? I had to remove my front bar and air to do my cam on the TE. can't imagine the XR would be any different. Of course you can always lift the motor. Measure the distance from the front of the block to the aircon condensor and then measure the length of the new cam and work out if it will fit that way. I would rather have the bar off so you can see where you are pushing it esp with all that red goo all over it. Its far easier if you have a bolt screwed into the end of the cam to hang onto for guiding it in. Then bolt the gear on afterwards and remember to do it up tight once the chain is on so it won't turn. This isn't an easy job - getting the water pump off isn't so bad but the the timing chain cover away from the block and sump is an exercise. You'll need 2 different pullers for the harmonic balancer and bottom timing chain gear
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
not here much anymore
Can be done without removing front bar but you will need to remove radiator.
RAM 1500
Bugger it just ordered some new ones... this thread can be deleted cheers Peter
#6 | |||
