Hi all... hopefully a simple answer for this one!
In my AU Monty as of late i've noticed when braking and coming to a stop the car will sometimes shudder like it's going to stall (hasn't stalled as of yet) anyone what generally this be due to, or can it be a plethora of possibilities?
Right out sideways
do you feel the shuddering in the brake peddle ? ifso warped disc's maybe?
but you do indicate you think it may be about to stall .....
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
its ABS lol... were you braking hard or in the wet?
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
![]() Join Date: Jan 2005
What have brakes got to do with the engine speed?
I'd check/clean the IAC/ISC valve, and also the power steering switch. mine shudders too, almost to stalling point, and I'm fairly certain mine is the power steering switch - which reminds me,; I should ring up for a new one!!
The Origional, The Best
i had a similar problem and it turn out to be a dying PCM after cleaning the ISC, resetting the ECU the whole lot
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
The PCM is the ECU isn't it?
#7 | |||
because when abs kicks in it feels like the whole front is shuddering.. its just a suggestion...
Ford beginner
It is on lpg? Mine does this sometimes but I'm not sure if it's an lpg problem or not (I have only noticed the shuddering on lpg mainly)
Got my power steering switch thing from AutoPro for $37 - hope it fixes my shudder!
#10 | |||
Walking with God
GK
#11 | |||
yeah i should have probably clarified this is all engine, brakes work fine no shuddering there... She has never stalled but came close. IAC valve makes a lot of sense, ill try the quick clean out of that tomorrow.. p/s switch is interesting too, if the iac makes no difference then that'll be the next area of focus. Where abouts is the switch located? near the rack or... ?
#12 | ||
Getting it done.....
THe suggestions made by JC are probably a good place to start. Also consider auto transmission. If the auto is failing to engage first fast enough (remember btr box has very tall ratios) then the rpm will drop too low in second gear and you risk stalling it. It isnt' all that common but it can happen, even if the shift is jsut delayed a bit. Often dirty/burnt fluid or other auto issues (which we all know can happen on high km btr boxes).
Edit: torque converter lock up issues also cause this sensation....if it doesn't unlock fast enough its basically a manual in too high a gear with the clutch out....
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... Last edited by Swordsman88; 03-05-2009 at 12:54 AM. |
#13 | |||
#14 | |||
#15 | |||
growing up is optional
Not all that hard to diagnose. Try slowing to a stop before the convertor has had a chance to lock - it should be ok. Then go drive until it does lock, then stop. If it shudders / stalls then you have a lock up problem. |
#16 | ||
Well, ISC is clean, and it works, but car still shudders/nearly stalls; that is until I adjusted the idle screw. The white paint used to mark it from factory was cracked, and a bit over half a turn saw the pattern in the cracked paint line back up, so i think thismay just have worked it's way loose over the 180,000+ km. i've used a 4mm nut to act as a lock nut now, so we'll see how that goes tomorrow. Idle is now more 750 to 800 instead of 650 to 700, which just sounds a bit better and is as per specs in the haynes manual.
#17 | ||
Idling is good - when coming to a stop, it drops down to about 650 and then stabilises at about 750 (previously was dropping as low as 500 rpm, and on the odd occasion, it was stalling).
#18 | |||
Walking with God
GK
#19 | ||
A little bit off topic, what is the idle rpm for an AU I6
#20 | |||
#21 | |||
#22 | ||
That is where the problem lies with mine. It is a touch under 600rpm in drive but the idle screw has never been touched so it must be a sensor or such that connects to the ISC that is playing up. I've tried almost all of them. Finding my problem seems to be harder than finding Bin Laden...
#23 | |||
