My falcon is leaking power steering oil from the axis of the pulley. Shall I replace the whole power steering box? Any work around?
Thanks in advance. |
Flairs - Truckers Delight
By the pulley, i assume you mean the pump/reservoir?
yes, the leakage is from the axis of the pump. I can see the oil on the pulley.
Yeh easiest way is just to grab another pump from a wrecker, when filling up make sure you use the correct fluid as any old fluid wont do.
Thanks mate. Do you know if I need use a specific type of power steering oil for ford or just pick anyone?
just use AU trans fluid
Thanks mate. I'll try to find a replacement.
i think i have seen them on ebay(neweys) , don`t remember the price......it might be worth a look though.
#9 | |||
Boost Addict
wrong Agri fluid is what AUs and Bs take, otherwise u will have a whiney bi*** on your hands
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
I'm about to change my high pressure line and do a flush. I was also under the impression that you could use trans fluid. What is Agri fluid? What is it called on the label? Any particular brand to use? Where can I get it?
Boost Addict
Mobil 1 Agri fluid, the fluid in ur reservior should be a light golden colour and not red, which is first and best indication that its not DX fluid.
Agri stands for agricultural, all oil manufacturers make a version of it, so take a pick. The Agri fluid is a touch heavier than the DX fluid and has slightly different characteristics. It reduces many of the typical whining and airation problems that Falcons had for 2 centuries. Great fix for older Falcons which have such problems. oh and BTW Falsons take 95LE Tranmission fluid and not DXIII.
#12 | ||
![]() Join Date: Dec 2006
Sounds like the seal has gone , it is a $5 part but not so easy to replace
You have to remove the pump and disassemble and press it back together Easier to swap the pump for most people Agri is the oil as has been said |
gone fishing
I use valvoline formula "F" the one with the picture of the AU on the front. and I still have the original power steering everything after 270Klm
Cheers Whiskers |
#14 | ||
Thanks everyone.
I got a used pump via Ebay. Looks everything is all right now. |
#15 | ||
Formally FairmontPom
Mine is leaking too, not dripping, just 'moist'... is replacement the only reasonable cure ? What sort of dollars are we looking at ?
1998 XH Falcon V8 S Pack, white, couple of dents. Bogan project 2020 PX3 Ranger XLT 4x4, 10 speed BiTurbo, Tech Pack, Black wheel pack, HSP powered roller shutter, LED fogs, tailgate central locking and auto fold mirror upgrades. |
#16 | |||
You'd better to find out the reason of leaking. If it's the pump, I bought one from Ebay. You should be able to find a used pump there at about $30-40. Also someone is saying that you can rebuild the pump by replacing the seal.
