Yep, owns a '99 AU.
Hi, I'm toying with the idea of fitting an air dam or combination bar cover/air dam, whatever is available. From what I've been reading, a TE50 or TS50 front may fit.
Is this correct ? If anyone has gone this way with a series 1, have you got any stories and pics ? AWC's website appears to be not working. The car's got the stock plastic streamlining and skirt under the fans, which is good and was one factor that enabled Ford to make the AU fairly low drag, but I want to play around with the aerodynamics a bit. |
