Ford Performance Club of ACT Owners Club Discussions General Chat |
07-01-2009, 10:38 PM | #1 | ||
"The costing for that kind of custom work is expensive and is kind of
reinventing the wheel somewhat. Ford have done the hard yards in desiging/building a turbo XR6 so the best option would be to either find a BF turbo wreck and transplant the engine as required or to source a XR6T and sell your XR6. An estimate on drive in drive out with a second hand low kilometer turbo engine transplant for your car would be $8900-$12900 depending on what other options you wanted at the time." WTF?
Previous - Mazda 2 Genki BF XR6 - Seduce BF MK II XR8 - ToXiC... Toyota Camry Altise After a patient 2 years... Now Driving... 2010 FG XR6 - Sunburst! |
07-01-2009, 10:43 PM | #3 | ||
Seriously, how hard can it be to put a turbo onto a BF XR6
07-01-2009, 11:06 PM | #4 | ||
Not overly if you mechanically minded enough to do it yourself, otherwise the labour alone will be in the thousands of $$. Not inc. parts. Either way it will cost upwards of 3-4k BARE minimum. You could sell the XR6 for 15k easily, and 20k gets you into a BF Turbo. Easy choice IMO.
07-01-2009, 11:06 PM | #5 | ||
Not worth it with the re-sale side of things,just trade it mate.
07-01-2009, 11:33 PM | #6 | ||
I would definately recommend trading. Putting a turbo on your xr6 brings emissions tests, engineers reports, and insurance hassles that you can avoid by getting a factory turbo.
Be prepared for pain when they make you an offer on the trade. BA XR6T's can be had sub $10K nowadays. Performance upgrade is well worth it though. |
08-01-2009, 11:34 AM | #7 | |||
GT-P With An Ego
There's a fair few differences between a NA XR6 and the T version from factory. The engine itself is different (lower static compression better conrods and valve springs etc.), then there's the turbo, intercooler, pipework, ECU is different (it's got extra inputs and outputs, not just the tune), this means the engine loom is different too, gearboxes are different (auto's are strenthened, different torque converter, manuals get bigger clutches), diff is different (non turbo get s BW78, turbo and V8 get the BW84), those little turbo badges aren't cheap (lol). I'm sure I've forgotten stuff. So parts will cost you a bit, plus it's essentially a full rebuild of the car, so labour will kill you. If you could do the work yourself it'd still probably take several weekends (car unusable for weeks). As suggested, investigate a car swap instead, will be cheaper both now and in the long term.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
08-01-2009, 11:46 AM | #8 | ||||
Cane Farmer
The engine loom is the same, only there is an 'extra' loom to control the turbo. I looked into doing a turbo conversion. And it was a pretty easy job and woulda cost very little. You do not need to run a turbo ECU. As long as you have something like a flash tuner, and a boost controller it'll work. Custom tunes are a must. COuple of issues are the sump will need to be drilled and tapped for the oil drain line. And due to the higher compression of the N/A motor, boost levels must be kept lowish so as not to lunch it. If anyone wants to know more, PM me. If you were gonna go turbo, but didnt want to buy a new car,doing the conversion would be the easiest solution. Doing a transplant would just be a waste and not very cost effective. Edit:- As far as I am aware, the 4spd autos are the same in N/A and T models. Only difference in driveline is the turbos come with a solid drive shaft (n/a's have a hollow) and LSD as standard.
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
08-01-2009, 06:10 PM | #9 | ||
Problem with trade is im still paying this one off :P 4 years to go on the finance *sighs* by then i'll be over it and wanting a 8, hell, i'll probably be a holden fan by then >.> God forbid
08-01-2009, 06:16 PM | #10 | |||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
08-01-2009, 06:18 PM | #11 | ||
Ok stupid question, but, zf?
08-01-2009, 06:34 PM | #12 | |||
08-01-2009, 06:37 PM | #13 | ||
GT-P With An Ego
ZF = The 6 speed auto.
08-01-2009, 08:09 PM | #14 | ||
Ah, no, 4 speed unfortunatly :(
So is there ANYTHING i can do to it then? my poor baby needs more GrUnT!
08-01-2009, 08:26 PM | #15 | ||
GT-P With An Ego
Check out the other areas on this forum, there's specific topics about getting more power from the I6's in B series.
I don't think anyone in this club has a n/a BA/BF XR6.
08-01-2009, 08:33 PM | #16 | |||
IWCMOGTVM Club Supporter
Have a read in there. http://www.fordforums.com.au/showthread.php?t=49929 Talk to Doogster (13.75 qtr unopened) or XRchic.
Daniel |
13-01-2009, 12:28 AM | #17 | |||
Boss 335
13-01-2009, 07:34 PM | #18 | |||
At Sea. Missing the Ts
http://www.fordforums.com.au/showthread.php?t=11245292
BF FANTASY XR6T Winter White FG XR6T Ute Mods: Herrod S/S Cat Back -Chrome 18" BSA 291 (Blades) - F6 CAI, Bosch Injectors, PWR Intercooler RDP tuned. WWW.RDPMACKAY.COM.AU POLEPOSITION TRIPOD and XForce gauges The T has a new garage buddy - 2010 FG XR6T Ute |
16-01-2009, 08:08 AM | #19 | ||
"Scott.
The main mods to get the best performance out of your XR6 without a turbo or supercharger is: - Custom cold intake $695 - Custom cold thermostat $120 - Full exhaust system fitted (headers, cat converter, cat back exhaust & tip) $1975 fitted - Custom tune $990 - Flash box $695" Expensive?
16-01-2009, 08:34 AM | #20 | ||
B-Series Moderator
Well if you can't trade it for a turbo, perhaps a supercharger kit is the way to go. Will cost you about $5,000 for a Raptor or Capa kit, but you can fit it yourself if your are mechanically minded. You would get about 210+rwkw.
BF MKII XR6 Turbo 2007 (Flare) ZF Auto 380rwkw - 11.68 @ 120.94mph 60ft=1.97 Custom Tune, Exhaust. injectors.1.2K Plazmaman 1.2K Plenum kit Now with bigger turbo and 426rwkw. |
16-01-2009, 08:46 AM | #21 | ||
"KF34 VORTECH SUPERCHARGERS - BA-BF XR6 & 6CYLS
The Vortech centrifical style supercharger package is a great setup for those wanting the thrill of forced induction supercharging from their BA-BF 6cyl. This package represents great value for the performance supplied. The base kit includes all the components required for fitting the supercharger which is then custom tuned on our dyno to deliver you the best in performance. Our tuning level on the base kit will deliver 305 fwkw of power at 8 psi of boost for the BA-BF 6cyls. This package is a bolt on upgrade and can be fitted and tuned in 2 days. KPM recommends this kit as a base for further upgrades and modifications if needed in the future. Cost. $6995.00 inc. GST Flash Tuning Software $995 extra if needed."
18-01-2009, 03:31 AM | #22 | |||
Fastideous Car Owner
Not quite less than 10k... but a 2004 xt tricked up to look like an FPV with all the bodykit etc and interior, with an XR6Turbo motor in it for $15000... check it out... http://www.carsales.com.au/used-cars...bo&distance=25
Never take a sleeping tablet and a laxative on the same night ..... oh no..... : |
18-01-2009, 05:05 AM | #23 | |||
Boss 335
16-12-2019, 06:02 PM | #24 | |||
I have a few questions in relation to this as I have a BF 2 Fairmont Ghia which im part way through starting the conversion, if you could shed some light that'd be great! |
17-12-2019, 06:50 AM | #25 | ||
17-12-2019, 10:54 AM | #26 | ||
I think of all the little problems not forecasted i.e. doing maintenance and finding parts are different or not compatible. Less drama just buying an XR6t.
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
17-12-2019, 12:53 PM | #27 | ||
18-12-2019, 02:46 PM | #28 | ||
YES, All the turbo boxes whether manual or auto are different to their N/A equivalents
AUII XR6, BF Built Turbo engine, SOON TO BE FG ENGINE... FG head and inlet manifold. GTX3582R, KPM 1500cc injectors, Process west rail and internal pump surge, Tuned by CMS, 370rwkw. 6 speed manual, NPC twin plate clutch, mal wood under dash hydraulic clutch. 4 pot brembos and territory rears |
18-12-2019, 03:40 PM | #29 | ||
02-04-2020, 04:20 PM | #30 | ||
yes also different. and BA-BF-FG ECU's are not compatible
