Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > ORSM Ford Cruise Car Club
ORSM Ford Cruise Car Club The one and only place for the ORSM Ford Cruise Car Club members Forums
Old 03-01-2009, 09:41 PM   #1
ORSM-XT
ORSM Ford Cruiser
ORSM-XT's Avatar
Default ORSMXT Steering Shudder/Vibration?
Hello ORSM Ford Cruisers,
I just discovered a rapid steering vibration at low speeds. just as you turn the wheel left or right lock to lock.
ive got King Springs Just Lows and 20"x8.5" Wheels.
I checked the power steering fluid (not that I would let in run dry), watched the supension as my dad turned the wheel, watched the steering rack as he turned the wheel.
and i got nothing
im stumped
hopeing that some ORSM brains would be able to help me.
Thank You in advance
Cheerz,
P.S. I have posted this in the contempory falcons thread
Lowered Subaru Forester
Linky Linky
ORSM-XT is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2009, 11:03 PM   #2
ORSMXR.
How many Ks on orsmxt? I suspect it could be the top ball joints
ORSMXR. is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2009, 09:10 AM   #3
ORSM-XT
ORSM Ford Cruiser
ORSM-XT's Avatar
54,000kms
Cheerz,
Linky Linky
Old 04-01-2009, 01:00 PM   #4
ORSMXR.
Hi Matt, You could also check front hubs as they can go at anytime. Have you checked your rims a lead weight may have fallen off and this can cause vibration whilst driving. Cheers Tony
Old 04-01-2009, 01:55 PM   #5
vandrsxr6
Force Fed Fords
vandrsxr6's Avatar
Go and get a balance on the rims.
Failing that it could be brake shudder in the front rotors.
Are they still the factory rotors?
The factory rotors are renowned for warping. If this is the case, rip them of and put some DBA slotteds in.
BA XR6 TURBO
310rwkw and always chasing more
Now with 6th Gear
RAPID PERFORMANCE
ORSM FORD CRUISER
vandrsxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 10:27 PM   #6
ORSM-XT
ORSM Ford Cruiser
ORSM-XT's Avatar
ITS OK
ORSM-XT
is all good
my mate has a BA on 20"s and he has the same problem. it happens after it goes on a hoist. just air in the hoses.
I woulda loved the rotors to be warped. i had some slotted rotrs lined up
Thanks for the help guys
Cheerz,
Linky Linky
Old 05-01-2009, 10:29 PM   #7
05_ENFORCER
05_ENFORCER's Avatar
Originally Posted by ORSM-XT
ITS OK
ORSM-XT
is all good
Cheerz,
Please explain the part about air in the hoses
C
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2009, 11:16 PM   #8
JAKHMR
JAKHMR's Avatar
I had a similar problem and it turned out to be the sway bar links. Only found out after changing the sway bar and heard a knocking sound too. I also had a mate with 20's and he found that the wheels were the problem. They caused uneven wear on the inside of the tyres with which he found to be the cause of the shudder.
ORSM
Ford Cruisers of Victoria
Success is the good fortune that comes from:
Inspiration , aspiration , desperation , and perspiration
JAKHMR is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2009, 08:37 AM   #9
ORSM-XT
ORSM Ford Cruiser
ORSM-XT's Avatar
All it was is that i had a build up of air in my p/s hoses. something about putting it on the hoist and air gets in or sumfin
I may look into getting bf p/s hoses, that solves the problem.
Cheerz,
Linky Linky
