Old 11-09-2008, 07:33 PM   #1
sircapp
Default where's the oil filter????
hi folks
I've just purchased a 98 HC Mondeo and strike me dead, i cannot find the oil filter.
Has anyone able to let me know where it hides on the engine.
thanks
Andrew
sircapp is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2008, 12:17 AM   #2
Simon_Koala
Starter Motor ?
Its tucked up behind and under the engine quite nicely ...... if you look roughly to the rear (and up) of the engine on the drivers side you should find it. I had to take the great layer of plastic off the bottom of the engine bay (a feat in itself) to locate it. Its in a similar position to my galant's oil filter location.
09 Ford Focus LV XR5
Simon_Koala is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2008, 08:32 PM   #3
sircapp
thanks Simon
I found that by removing the front right hand tyre and undoing two screws that hold in a small section of the wheel well shroud, that i can gain easy access to the oil filter through the wheel well.
Andrew
