Has anybody experienced there auto going ''clunk'' just before you come to a full stop [while under brakes] Car has just had its 3000k service and this was its second visit for this problem but the service dept is trying to palm me off by saying other cars have had this problem going into first gear. What is even more anoying they think you would believe there crap its really puts me off buying an XR6.Anyway its booked in again this wednesday and I said it will be going back every week untill its sorted out.
Our 07 LS Ghia does the same thing and when mentioned at the first service, we were told 'all the autos do it, it's normal....'
#3 | |||
If anybody is thinking about buying a 4 speed auto Focus, think again, trying to sort out the problem is a real pain in the ***, according to ford the clunk that the gear box has is not that bad. What planet are these guys on.
i've never heard any ford auto of any of dad's go "clunk" going into first gear, ever. so it's obviously not normal. :S
I wanna XR5
these boxes are in the mazda 323 and 3, lazer and earlier focus, fn4ael /4f27e and has been around for sometime.
what a load of crap, take it to a trans specialist for check, A good one will give you much more info on about whats happening. This is not a normal thing for any auto to do.
Great Wall X240. Bouncing around the APY Lands Ex Ford owner and member of this great site for ages. South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@* |
My focus is about 7 weeks old with about 3000kms on the clock and yes, it's auto. My trans changes quite smooth through all gears, including going back into first. I've said this to others with waranty problems, and that is, dont put up with this crap. You have a new car that is under waranty and they have to fix it. Phone the Ford Customer Care Centre and take it up with them. You do not have to put up with the BS that comes out of the dealers mouths.
2013 FG MKII XR6 UTE |
I wanna XR5
Go to a Trans specialist, their advice can be used as bullets.
Some may give you a written letter. Get a second or third opinion
Focus TDCi
my mrs' mazda6 does the same thing...unfortunatly its no longer under warranty :(
#10 | |||
#11 | |||
Focus TDCi
has it worked for you? |
#12 | |||
I've tried the brake harder solution ![]() I'm taking it in for a check up at the end of this week. Cheers |
#13 | |||
#14 | ||
I also noticed that while in 'manual' mode, if I brake to a stop without 'manually' changing down it handles the down shifts OK till it goes back into first, then the whole car shudders and shakes as it goes into first.
It's due for a service is in the next couple of weeks, I will put it on the list of things to be looked at...... |
#15 | ||
Focus TDCi
if it does the clunk sound in [D], it will still do it when in [Manual] mode.
#16 | ||
I wanna XR5
I work on autos for a living, thats why i have a manual, LOL
But seriously this is not right, The problem can also be other things like TPS not set correctly, which can give high line perssure, valve body issues. you wont get trouble codes for this so too hard for ford!!! well if they let it continue trans specalist will love it, LOL
#17 | |||
#18 | ||
I wanna XR5
it could not be going into first that is making the shudder/clunk but one of the other clutches disengaging, i.e direct clutch.
Have to remind myself to looking in our tech books at work. some other transmissions will do this if clearances are not correct with the direct clutch.
#19 | ||
had my falcon in for a service (not ford dealer) and thought the trans was over due and so got it serviced too. Picked it up and told " auto serviced and we even udjusted the bands for you". Drove off and the first set of lights I came to slow down to a stop "CLUNK" which it never did before. Took it back and subsequently reduced but still there sometimes.
____________ *** For Sale *** Red Flame Auto Allan Moffat Special #280 |
#20 | ||
I wanna XR5
"we even adjusted the bands for you" LOL
If it has adjustable band/s its part of the trans service!!! service a trans every 20,000km or 12 months
#21 | ||
You can feel our LS change to first as you pull up at the lights, but I wouldn't call it a clunk. Its a very slight shunt I guess. Haven't bothered doing anything about it, because when you're used to BTR equiped E series cars its still 100x smoother
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
#22 | ||
I wanna XR5
Been doing some research.
Found from mate who is a ford dealer mechanic. They have had quite a few return with this issue. found to be the band apply servo pistons seal is buggered, maybe a bad batch. these pistons have a seal that is moulded onto the piston. this band comes on in 2nd and 4th so it is not releasing properly. This servo is under the valve body. so go and get it up your dealer. Anthony it will be the same issue with the 6 as it also has the same trans
#23 | |||
#24 | |||
#25 | ||
I wanna XR5
its not 1st you are feeling but the band which is applied during 2nd disengaging as it is in the process of changing out of 2nd and into 1st.
it is not disengaging fast enough and holding slightly while 1st is engaging. so when the band does release it lets go with a bang or a shudder. to tell you we see quite a lot of these boxes but in mazda's. some have only done 80,000 and have bad wear on a few parts, BUT most of these have not been serviced regular or not at all. These boxes do have some bad design faults SO SERVICE IT EVERY 20,000 or 12 MONTHS.
#26 | |||
Hey all Here's an update about my attempts to get my focus tranny "fixed" by Ford. I've taken my car to the dealer on two occasions. The first time they test drove it and admitted that there was a problem with the tranny thumping back into first gear after coming to a stop. But as Ford was not aware of this problem, all they could do was to let their engineering dept know and wait for a response. On the second occasion I took the car back for it's 3000km service and asked them to look at the tranny again as it's annoying the hell out of me. Again they kept the car for a whole day and I suspect they did nothing to try and find the fault with it. I asked to speak to the service manager who was at the dept's back room but he sent out one of his lackey's to explain to me the situation...great customer service goes out the window after they have your money. Feeling pretty ****ed off, I got home and rang Ford Customer Care They gave me a reference number blah blah blah "and we will contact you when our engineering dept has a solution, but bear in mind that it may be a long time as this is not common" Typical beat around the bush bullsht which I honestly didn't expect from FORD. I just want them to have a serious look at my car tranny and fix it. A few days later some very condescending chic from ford customer care rang me to "confirm" that they had spoken to the dealer and to do me a favour they will keep my case open just in case they find a solution to the tranny problem because in their expert opinion the noise or thump the tranny makes is normal operation. Bullsht. Wow thanks that made my day. Now i'll just sit here and wait for Ford to contact me sometime in the future. Some things I've learnt. Before handing over the money for a NEW FORD FOCUS, test drive it ( the one you are actually getting) NEW FORD WARRANTY for TRANSMISSIONS seems to be open for interpretation to Ford's advantage. I should have bought that VW Golf GTI instead. |
#27 | ||
I wanna XR5
tell them Wayne Phillis Ford at Christies beach in SA has done a few of these with this problem already, and fixed the problem!!!! look at last post on page 1
THAT IS NOT NORMAL OPERATION. We would never let a trans bumping to a stop leave our workshop! GET FORD AUST TO RING THE ABOVE DEALER SH!T dont you hate doing their leg work for them? I dont work for a ford dealer or ford.
Great Wall X240. Bouncing around the APY Lands Ex Ford owner and member of this great site for ages. South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@* Last edited by 20focus05; 18-09-2008 at 12:09 AM. |
#28 | ||
I wanna XR5
ZE08TEC
How have you gone with the fixing?
#29 | |||
#30 | |||
Hmmm, is this a somewhat regular occurance in LS-LV model auto's?
Likelyhood of trading my LR Zetec in on an auto LS LX or Zetec is high in the new year. And i wouldnt want to get one with a 'clunk'..... Quote:
