Old 12-07-2008, 09:41 PM   #1
fordon
fordon's Avatar
Cool xr8 intake manifold
I took the intake manifold off awhile ago and re-installed.
Silly me forgotten where the vacuum hoses go.
Has someone got a diagram of the intake manifold ?
maybe photos of engine bay that might show hoses around this area.
Cheers.
fordon is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2008, 11:24 AM   #2
james22
With da Warlords
james22's Avatar
Here's a few pics for you.
One hose goes to the brake booster
Another to the pcv valve at the rear of the manifold
And the little orange one that goes to some sort of regulator
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 14-07-2008, 12:14 PM   #3
fordon
fordon's Avatar
You are a champion bloke,
Ill go and see if it all makes sence :-)
Old 14-07-2008, 02:06 PM   #4
james22
With da Warlords
james22's Avatar
Glad I could help out. :-)
Windsor Warlords
AU III XR-8220
Old 14-07-2008, 02:14 PM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Show off :
Old 14-07-2008, 03:52 PM   #6
fordon
fordon's Avatar
only promblem now its running like a hairy goat :-s
Old 14-07-2008, 04:06 PM   #7
Peuty
Afterburner + skids =
Peuty's Avatar
If you had the mainfold off, then chances are you would probably have taken the intake off too? If so, check to make sure your MAF is plugged in properly, as well as the sensor that goes in the middle of the intake tube (forget what it's called)
Oo\===/oO
Old 14-07-2008, 06:03 PM   #8
b2tf
not here much anymore
b2tf's Avatar
whyd you take it off?
RAM 1500
Old 15-07-2008, 06:02 PM   #9
fordon
fordon's Avatar
I was painting it. :togo:
The promblem could be,I didnt use a new gasket or glue?
Just put old gasket on and tighten,the gasket seemed fine.
Idil rough/if you go accelerate and take foot off still is reving and slowing comes back to a rough idil,
Sucking air coursing this ? or a sensor ?
Old 16-07-2008, 08:52 AM   #10
james22
With da Warlords
james22's Avatar
It does sound vacuum related, Especially considering you did just pull your upper manifold off. I would try a new manifold gasket, and double check all your connections are nice and snug. Also make sure your TPS, IAC, MAF, and Heat sensor have all been reconnected since you finished.
Windsor Warlords
AU III XR-8220
Old 16-07-2008, 01:12 PM   #11
fordon
fordon's Avatar
I think my hoses are the same as your photos:-p
The hose from the rocker cover,that connects to your throtle body ?
I like your lion pic,i know how he feels,were dumb
Old 16-07-2008, 02:17 PM   #12
james22
With da Warlords
james22's Avatar
Rocker cover to throttle body is correct. You sure you've plugged all the hoses into your manifold??? There shouldn't be any connections left over.
Windsor Warlords
AU III XR-8220
Old 16-07-2008, 02:38 PM   #13
james22
With da Warlords
james22's Avatar
Windsor Warlords
AU III XR-8220
Old 16-07-2008, 03:14 PM   #14
fordon
fordon's Avatar
yes looks correct:-)
what about petrol ? went and started her today it was i sounding fine:-) than stoped wouldnt start. Grrr FFS
just drained the tanked and petrol is clear.
so im ganna try buy her sum nice yummy petrol and see what happens......
tank was just about empty and i put petrol in when i put manifold on........
Old 16-07-2008, 03:16 PM   #15
b2tf
b2tf's Avatar
just make sure the hose near the very back of the manifold closest to firewall is plugged right in - its a right bugger of a thing to get back in once youve had it out, sometimes you think youve got it on but it's not on far enough.
RAM 1500
Old 16-07-2008, 06:46 PM   #16
fordon
fordon's Avatar
all hoses seem well,
New petrol and seems to idil fine.
Issuie is when you tap accelarated and take foot off it keeps reving......than after about 6 seconds it goes back to idil.
Im thinking this means its sucking air around manifold? best thing replace gasket?
than go from there..........
im such a clats:-p
Old 23-03-2013, 12:31 AM   #17
bluestripes
Q - CAR
bluestripes's Avatar
Default Re: xr8 intake manifold
this is an old thread though hopefully still alive.
Can you guys tell me where the two black vacuum hose go on the manifold picture above ?? I know one is the brake booster though what is the second hose and which is which???
Reason - I m fitting a Trickflow R series to my new engine and i need to re plumb for the second hose.
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2013, 12:34 AM   #18
bluestripes
Q - CAR
Ok - now i know, I just re read the post more closely...
One to the brake booster and the other to the PVC valve.
Im assuming the twin plumbed hose goes to the booster ??
AU FORD STROKER
Old 14-09-2020, 04:13 PM   #19
MyNFII
Fly like a G6
MyNFII's Avatar
Can anyone assist in identifying the missing part for this vaccum line at the back of my Windsor V8 Intake Manifold. I assume it is an elbow joint that has popped off and this leads to the PCV Valve? if so where can i get one?
~ 2008 G6 in Ego ~
MyNFII is offline   Reply With Quote Multi-Quote with this Post
