Old 01-07-2008, 01:22 PM   #1
mmhmm
mmhmm's Avatar
Default ford telstar tx5
hi guys
i've recently had issues with my cousins tx5 telstar 93 model, which once we replaced the sparkplugs its performance was much better ( acceleration ) and speed pickup yet around 4000rpm it flutters or stutters , then it picks back up or it just wont go anywhere unlesss you ease the throttle. i've nottice this occurs when putting pushing the pedal on the floor it will just start stuttering but if you lightly accelerate it will be fine
it is a spark plug issue, previous spark plugs were denso gapped to like .5mm , it is a reconditioned engine
any advice would be great guys
mmhmm is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 02:14 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
could be the
air flow meter
a fuel filter or
clogged injector
fuel pressure regulator on the fuel rail
My car goes Brumm Brumm
Old 01-07-2008, 02:20 PM   #3
mmhmm
mmhmm's Avatar
hmmm but it works fine using the old plugs that was in the car?
the original plugs we use has no stutter on it ..... we are planning to do the fuel filter but how do we clean the injector?
Old 02-07-2008, 06:56 PM   #4
dirty hands
Over Thinker
off the shelf injector cleaner -goes into the tank
or you can get mobile injector cleaning service that comes to you
should be in the yellow automotive pages
Old 04-07-2008, 07:51 PM   #5
coop1er
I would check or replace the ignition leads. Just by chance, you didnt get any water into the spark plug wells did you?
coop1er is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2008, 03:07 PM   #6
mmhmm
mmhmm's Avatar
nope not one bit of water is in it, we've actually changed leads and now re-gapped them to .4mm and now it works? not the same amount of power/acceleration from what we got when we had it on 1.1 gappage of the sparks but it doesnt fluster
thanks for your input guys? why would it be needing such a small gap ?
Old 05-07-2008, 07:18 PM   #7
coop1er
The plug gap is meant to be 1.0mm isn't it?
If you cant run that size gap then there must be some weakness in your ignition system somewhere. I would start by inspecting your distributor cap and rotor.
You havent fitted a turbo or anything have you?
