Old 13-05-2008, 07:48 PM   #1
4dlvr
4dlvr
Default lr zetec vs laser sr2
as stated, what would win in say a 0-400m or a 0-100km/h race...
considering both are manual and in good condition with good drivers behind the two
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2008, 09:51 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Power and weight figures for each would be a good start
Old 15-05-2008, 12:47 AM   #3
4dlvr
4dlvr
zetec
Power 96 kW
Torque 178 Nm
Weight to Power Ratio 12.52 : 1 (kg/kW)
Kerb Weight 1202 kg
sr2
Power 98 kW
Torque 174 Nm
Weight to Power Ratio 12.26 : 1 (kg/kW)
Kerb Weight 1201 kg
96 EF FAIRMONT
215rwkw @7psi
Old 15-05-2008, 10:09 AM   #4
melbzetec
melbzetec's Avatar
Sheesh. Close figures.
Probably gets down to gearing now. And I get lost there!
Old 15-05-2008, 11:10 AM   #5
BlackLS
yum
Probably nothing between them. Down to drivers moreso than gearing.
2005 LS Focus LX
250,000kms.
Old 15-05-2008, 06:38 PM   #6
FOCUSonTHIS
FOCUSonTHIS's Avatar
Well if from the start if you don't get much wheel spin and can find second, I think you would be in a clear shot of the lead
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 15-05-2008, 08:48 PM   #7
zetec
Zoom Zoom
zetec's Avatar
And when you turn the corner, the Focus starts to win. Given there'd be virtually nothing in it in a straight line, the Focus would be the better car overall as a driver's car. It has an atural advantage in that it's newer and thus SHOULD be better, but it's a world-reknowned brilliant handler. Point-to-point, the Focus Zetec would HAVE to be faster.
Laser will be cheaper, but the focus will be the better overall driver's car and with the German build quality, arguably better built than the Japanese-built Laser.
I decided between runout SR2 and new Zetec back in February 2003 and settled on the Zetec brand new. Never regretted that for a second.
2012 Mazda3 MPS
Old 15-05-2008, 09:06 PM   #8
XR Martin
XR Martin's Avatar
LR Focus was built in Spain, not Germany.
Id take the Laser quality over the Focus quality anyday.
2004 BA wagon RTV project.
Old 15-05-2008, 09:10 PM   #9
Smoke Pursuit
I thought the Focus was built in South Africa?? I know the LS is but i also thought some of the later LRs were to.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2008, 09:25 PM   #10
Spazzsfocus
RS Dreamer!
Spazzsfocus's Avatar
wow get your facts right.... _
LR focus CL and LX were made in Spain... not the Zetec's which were made in Germany!
LS focus are made in South Africa except the XR5 (same goes for LT)
Spazzsfocus is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 01:13 PM   #11
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
I've got a LR LX and it is DEFINATELY built in Germany.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 02:01 PM   #12
Spazzsfocus
RS Dreamer!
sorry Eddie... I should check my own facts! :
I can also confirm for certainty that my LR Zetec is from Saarlouis, Germany. So I knew that XR6 Martin was wrong... plus I've had first hand experience with the last of the Laser's (from Japan) and I think that IMO the Focus killed it in build quality...
Old 16-05-2008, 06:35 PM   #13
4dlvr
4dlvr
i was tossing up between a sr, sr2 or a zetec. i picked the zetec, i drove the sr and it did not go or handle as good as the zetec. the build quality is very good, but i love the zetecs build...
i love the zetecs looks but i think the sr2's abit NICEer..
i just wanted to see if anyone had driven the two
96 EF FAIRMONT
215rwkw @7psi
Old 16-05-2008, 11:12 PM   #14
zetec
Zoom Zoom
zetec's Avatar
OK OK I'm here to save the day and set it all straight.
LR Hatches and ST170 ALWAYS came from Saarlouis, Germany only.
LR Sedans ALWAYS came from Valencia, Spain only
LS/LT Hatches and sedans have ALWAYS come from South Africa only.
LS/LT/LV XR5 Turbos have ALWAYS come from Saarlouis, Germany only.
LT Focus Coupe Cabriolet has always come from Italy only.
Here ends the reading.
2012 Mazda3 MPS
Old 17-05-2008, 11:09 AM   #15
Spazzsfocus
RS Dreamer!
Thanks for clarifying that zetec! :
I know its way off topic but where are the Fiesta's manufactured? I was under the impression that they were German designed but built in South Africa...
4dlvr: in terms of handling, I agree with you... however I can't bring myself to agree on the looks of the Laser being 'nicer'... I just can't see it (but then again I'm biased now towards the Focus!)
Old 17-05-2008, 03:00 PM   #16
photn
AFF Post NAZI
photn's Avatar
All Fiesta's Are Designed and Built in Germany Or belgium.. i always get the two confused. either way. Build Quality = TOP!
Old 17-05-2008, 11:35 PM   #17
zetec
Zoom Zoom
zetec's Avatar
Holy cow, it stuns me how little people know about where they're all built !!
Fiesta is built in Cologne, Germany.
Mondeo is built in Genk, Belgium (along with S Max and Galaxy)
2012 Mazda3 MPS
Old 18-05-2008, 08:09 PM   #18
BlackLS
yum
Sorta good in a way that Ford's getting the German engineered message across...
2005 LS Focus LX
250,000kms.
