Old 07-05-2008, 03:56 PM   #1
mudwaa
Default Crazing in paint work
i hanent seen this in the fault list but when i polished my car on the week-end i notice two spots where the paint has crazing. The car was taken in 3 or 4 times from the day od pick-up for paint defect repairs but this problem is new. Car is about 8 months old with 13000km. Oh and the suspension sounds like it is about to fall out from under the car on every small bump. Have jacked the car and pulled and tapped every visible component to no avail. Is front and back (mostly back). Sounds a bit like if the jack was loose and bouncing around on every bump or rut but i took the jack out. Thinking maybe the springs themselves. Looking under the car i see little to no sound deadening which im sure being a hatch-back lets a lot of noise thru. Any coments appreciated
mudwaa is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2008, 06:59 PM   #2
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
Not trying to be a smartarse, but did you check your wheel nuts?
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2008, 03:22 PM   #3
mudwaa
yup, checked all wheel nuts. bout the only thing i havent done is pull the rear interior out to get a look at the top of the struts. thinking maybe summin loose there.
